Home » Language IDEs » ServerTools (WTP) » Error creating zip file {Project Name.jar}
Error creating zip file {Project Name.jar} [message #160835] Wed, 15 February 2006 12:27 Go to next message
I have Eclipse 3.1.1, JDK 1.5, WTP 1.0, Axis 1_2_1, and Tomcat 5.5.15.
Within my workspace I have one Web Service, and Web Client project. I
also have 5 other projects. The Web Service project calls each of the 5
other projects for specific processing but they are standalone Java
projects. I also have a Servers project.
My Web Service for the most part runs, however, when I go to perform a
Clean, Project->Clean I randomly get an error message like this:
Publishing to Tomcat v5.5 Server @localhost...
Publishing failed
When I click details I see the following:
Error creating zip file {Project Name}.jar: ZIP file must have at least
one entry
In this example I get one of these messages for four of the five java
projects that I have created. What is interesting is that if I turn
around and run the same clean, the message may only list one or two of the
projects. There is no consistancy. In addition, there are times that it
will not list any of the projects. To test this, I just re-ran the Clean
and I only had one of the projects listed.
I would like to know how to fix this?
I would also like to know what the impact on my project is that this error
message is causing?
Ben
Re: Error creating zip file {Project Name.jar} [message #160859 is a reply to message #160835] Wed, 15 February 2006 13:14 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=121742 may have addressed
this.
Larry
> Publishing failed
> one entry
> the projects. There is no consistancy. In addition, there are times
> that it will not list any of the projects. To test this, I just re-ran
> the Clean and I only had one of the projects listed.
> error message is causing?
> Ben
Re: Error creating zip file {Project Name.jar} [message #160898 is a reply to message #160859] Wed, 15 February 2006 15:31 Go to previous message
Larry,
I want to thank you for your quick resposne and comments. I went back to
capture detailed information about the error and it worked. I can't tell
exactly what I did differently, since it had not been working since
yesterday but had been working before then.
Ben
Previous Topic:Incomplete Deployment on WTP 1.5
Next Topic:integration ejb project with client project
Current Time: Mon Sep 01 00:33:36 EDT 2025
Powered by FUDForum. Page generated in 0.03803 seconds
