Home » Eclipse Projects » Eclipse Platform » Editor reuse broken in M5
Editor reuse broken in M5 [message #160808] Sun, 23 November 2003 23:42 Go to next message
Sometimes it is necessary to have a particular file type open in a single
editor instance. There has been no explicit support for this in Eclipse
but there was a nice workaround for it up to and including version 3.0M4
that went something like this:
- define an external editor launcher in whose open() method we do the
following:
if the editor is already open {
editor.markInNavigationHistory
editor.setInput(newInput)
} else {
get the editor's description and mark it as internal
workbenchpage.openEditor(newInput)
set the editor as external so this launcher will be used again
There is now (from M5) no way to set an editor's internal/external
property in the EditorDescription so that this approach no longer 'works
around'.
There is a new IReusableEditor interface but I can't see how this helps at
the moment. Are there any plans to deal with single editor instances with
a working navigation history? If not, could we have setLauncher() and
setOpenMode() in EditorDescription made public so that the approach
described above will work again?
Henrietta
Re: Editor reuse broken in M5 [message #160846 is a reply to message #160808] Mon, 24 November 2003 04:31 Go to previous messageGo to next message
Originally posted by: thomas_maeder.ch.ibm.com
Can't you implement the editor as a wrapper around a shared instance?
I.e. whenever an instance of the editor is opened, it forwards to a
single instance you maintain somewhere?
Thomas
> but ...
Re: Editor reuse broken in M5 [message #161387 is a reply to message #160846] Tue, 25 November 2003 00:43 Go to previous messageGo to next message
No, I'm afraid that doesn't work - in our proposed wrapper EditorPart's
init() method we would need to do:
setSite( singleInstanceEditor.getSite() );
because to do:
setSite( site );
just creates a new window as usual, but when our init() method completes
there is a guard in EditorManager that ensures we're connected to the new
site:
private void createSite(...) throws PartInitException
part.init(site, input);
if (part.getSite() != site)
throw new Exception("EditorManager.siteIncorrect" );
So using the wrapper approach we get either new windows or exceptions. In
any case there must be a better way of organising this than creating a
whole editor part just to access a singleton? And when and how would
these new wrappers be destroyed?
Would it be possible to make those EditorDescription methods public so
the approach used in M4 and previous versions works again? In the absence
of some new reusable editor architecture, it's tried and trusted.
Henrietta
> Thomas
> > but ...
Re: Editor reuse broken in M5 [message #161490 is a reply to message #161387] Tue, 25 November 2003 07:07 Go to previous messageGo to next message
> because to do:
> setSite( site );
> site:
I don't understand this requirement. You'd have to expand on what
exactly you're doing and why you can only have a single editor instance.
You can do ref counting; parts are disposed.
It just smells like hackery, sorry (I can't speak for the platform team,
though). Perhaps if you describe the whys and hows of your problem,
somebody can suggest a better solution.
> Henrietta
> Thomas Mäder wrote:
Re: Editor reuse broken in M5 [message #161845 is a reply to message #161490] Tue, 25 November 2003 18:26 Go to previous messageGo to next message
Thanks a lot Thomas,
This requirement would be common to a broad class of problems. Any time an
editor has a large startup time, consumes a lot of resources and is
configured
by a comparatively small 'edited file' then a singleton editor is
necessary.
Think 3D as one example.
Could you explain in a little more detail what your wrapper solution
involves? Would these wrappers be EditorParts? If so these parts are owned
by the framework and are normally destroyed when you press the close
button.
How do you propose I do 'ref counting' and how would I get the framework
to drop a reference to an editor part when it doesn't have its own GUI
(it's delegating to the singleton). Doesn't an EditorPart have a good
deal of GUI baggage (hence the reasonable Site exception) and how would
you prevent this baggage from being created?
The approach you describe as 'hackery' is simple and has worked well sice
the
days of 2.0. Why prevent this broad class of problems from being solved
within Eclipse for the sake of making two methods public?
Martin
> > because to do:
> > setSite( site );
> > site:
> > Thanks,
> > Henrietta
> > Thomas Mäder wrote:
Re: Editor reuse broken in M5 [message #162081 is a reply to message #161845] Wed, 26 November 2003 06:14 Go to previous messageGo to next message
> configured
> necessary.
Aha, I see.
> button.
The wrappers would be IEditorParts, and they would reference an instance
of the shared object. When eclipse calls the dispose() method on the
editor part, you decrement the reference count. Of course, if the bulk
of your editor is in the UI (i.e. the widgets), you're out of luck.
> the
Your real problem is: "I'd like to always reuse the same editor
instance". The solution you had in earlier builds is a workaround
because you can't express what you really want in eclipse.
The real fix would be to add a method openEditor(..., boolean
reuseInstance) to the eclipse framework (file a bug report!). Sometimes
hackery is the only way you can solve a problem.
In the meantime, why don't you define two editors, one external and one
internal. You can set the external one as the default editor for the
particular file type you're interested in. In the open method of the
external editor, you do this:
MyEditorType existingEditor= findEditorInstance(file);
if (existingEditor != null)
editor.setInput(bla);
else
openInternalEditor(file);
your users could be fiendish and manually change the default editor
type, but that's their problem, not your's.
Thomas
Re: Editor reuse broken in M5 [message #162539 is a reply to message #162081] Wed, 26 November 2003 17:16 Go to previous messageGo to next message
That's all really helpful. I had the same idea some time back with the
internal / external editor combo. Unfortunately, the navigation history
remembers that you opened the first editor as internal and when you do
ALT-LArrow or ALT-RArrow it's the internal editor that get's used again
and more windows pop up - no solution for me I'm afraid.
I'll look again at your wrapper approach but I can't currently see why
eclipse would "call the dispose() method on the editor part" unless it's
initiated by a close button on the GUI (which it wouldn't have). I guess
I'll have to try and close it myself from the singleton when the selection
changes (any idea how to do that?). If I can't get it working I'll do as
you suggest and file a bug report asking for:
openEditor(..., boolean reuseInstance)
Thanks a lot,
Henrietta
> > configured
> > necessary.
> Aha, I see.
> > button.
> > the
> else
> Thomas
Re: Editor reuse broken in M5 [message #162578 is a reply to message #162081] Wed, 26 November 2003 19:27 Go to previous messageGo to next message
I've tried again with wrappers but I don't think it can be made to work.
When a new IEditorPart is created it has to accept the IWorkbenchPartSite
that it's given in init() (i.e. the same site must be returned from
getSite() or an exception is thrown). The IWorkbenchPartSite seems to
correspond visually to a new editor tab and there is no way of preventing
it's creation. I'm concluding there is no way of always reusing the same
editor in M5 and beyond and I've filed a bug report (47600) to that effect:
Henrietta
> > configured
> > necessary.
> Aha, I see.
> > button.
> > the
> else
> Thomas
Re: Editor reuse broken in M5 [message #172427 is a reply to message #160808] Fri, 19 December 2003 08:39 Go to previous message
Originally posted by: daniel.megert.gmx.net
Henrietta,
if you didn't already do so the best would probably be to file a feature
request where you explain why this feature might be a good addition.
Dani
>following:
> } else {
>around'.
>Thanks,
>Henrietta
Previous Topic:Associating a project with a snapshot view of clearcase
Next Topic:Re: Error instantiating java editor
Current Time: Mon Sep 01 04:06:15 EDT 2025
Powered by FUDForum. Page generated in 0.09803 seconds
