Home » Eclipse Projects » Eclipse Platform » Problem installing plugins on R3.0 M5
Problem installing plugins on R3.0 M5 [message #160770] Sun, 23 November 2003 16:11 Go to next message
Originally posted by: jmordax.terra.es
Is there a new mechanism to install plugins via File system in this new
version?
I have unzipped into /features and /plugins for example the Samples zip
and when I start Eclipse it doesn't detect the new feature. ¿?
I did the same test with other plugins like Eclipse-games with the same
result.
Any comment?
Thanks in advance,
Chemi.
Re: Problem installing plugins on R3.0 M5 [message #160908 is a reply to message #160770] Mon, 24 November 2003 08:58 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
I had the same problem, but it was solved. I have selected Help-->Software
Updates-->Manage configuration (if there is no such menu item you have to
'customize perspective' and add 'software updates' command to the
perspective), and enabled the feature I wanted.
HTH,
Csaba
"Chemi" <jmordax@terra.es> wrote in message news:bpr7ra$ml1$1@eclipse.org...
> version?
Re: Problem installing plugins on R3.0 M5 [message #160965 is a reply to message #160908] Mon, 24 November 2003 09:53 Go to previous messageGo to next message
Ok. Thanks a lot.
So, is this the new way to do this now? Is there any preference to
enable the automatic detection when starting up (like previous versions)?
Thanks again,
Chemi.
Horváth, Csaba wrote:
>Hi,
>HTH,
>Regards,
>Csaba
>>version?
>>result.
>>Any comment?
>>Thanks in advance,
>> Chemi.
Re: Problem installing plugins on R3.0 M5 [message #161113 is a reply to message #160965] Mon, 24 November 2003 12:09 Go to previous messageGo to next message
Originally posted by: dorian.birsan.net
"Chemi" <jmordax@terra.es> wrote in message news:bpt682$jka$1@eclipse.org...
> Ok. Thanks a lot.
I think this is a side-effect of some changes in the platform code and I
will investigate it.
On the other hand, this new behavior seems more appealing, because it could
lead to removing the update reconciler from the sensitive startup process,
and would have the user going through the update manager (Manage
Configuration...) to enable the newly unzipped features.
> Thanks again,
> Chemi.
> Horv
Re: Problem installing plugins on R3.0 M5 [message #161145 is a reply to message #161113] Mon, 24 November 2003 12:33 Go to previous messageGo to next message
--------------070400070105000208070700
Content-Type: text/plain; charset=us-ascii; format=flowed
>>Ok. Thanks a lot.
Well, it was a really easy way to install things.... and the platform
asked you to validate the installation or decline it (as it seems it is
doing now by default). I don't know. I think it is a matter of likes....
and I was used to the other way.
So theoretically, is this going to be the new way to work? Or is it a bug?
Thanks for your comments,
Chemi.
Content-Type: text/html; charset=us-ascii
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body text="#000000" bgcolor="#ffffff">
dorian birsan wrote:<br>
<blockquote type="cite" cite="midbptdsb$utj$1@eclipse.org">
<pre wrap="">"Chemi" <a class="moz-txt-link-rfc2396E" href="mailto:jmordax@terra.es">&lt;jmordax@terra.es&gt;</a> wrote in message <a class="moz-txt-link-freetext" href="news:bpt682$jka$1@eclipse.org">news:bpt682$jka$1@eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Ok. Thanks a lot.
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
likes.... and I was used to the other way.<br>
<br>
bug?<br>
<br>
Thanks for your comments,<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp; Chemi.<br>
</body>
</html>
--------------070400070105000208070700--
Re: Problem installing plugins on R3.0 M5 [message #161371 is a reply to message #161145] Mon, 24 November 2003 22:44 Go to previous messageGo to next message
------=_NextPart_000_009C_01C3B2DC.96123230
charset="iso-8859-1"
Currently it is a bug introduced by RCP, or at least it appears so. We =
are tracking it down.
"Chemi" <jmordax@terra.es> wrote in message =
news:bptfk3$v1$1@eclipse.org...
Ok. Thanks a lot.
enable the automatic detection when starting up (like previous =
versions)?
=20
On the other hand, this new behavior seems more appealing, because it =
could
lead to removing the update reconciler from the sensitive startup =
process,
Well, it was a really easy way to install things.... and the platform =
asked you to validate the installation or decline it (as it seems it is =
doing now by default). I don't know. I think it is a matter of likes.... =
So theoretically, is this going to be the new way to work? Or is it a =
bug?
Chemi.
<HTML><HEAD><TITLE></TITLE>
<META content=3D"MSHTML 6.00.2800.1276" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Currently it is a bug introduced by =
RCP, or at=20
least it appears so. We are tracking it down.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<BLOCKQUOTE=20
<DIV>"Chemi" &lt;<A =
href=3D"mailto:jmordax@terra.es">jmordax@terra.es</A>&gt;=20
wrote in message <A=20
href=3D"news:bptfk3$v1$1@eclipse.org">news:bptfk3$v1$1@eclipse.org</A>...=
</DIV>dorian=20
birsan wrote:<BR>
<BLOCKQUOTE cite=3Dmidbptdsb$utj$1@eclipse.org type=3D"cite"><PRE =
wrap=3D"">"Chemi" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:jmordax@terra.es">&lt;jmordax@terra.es&gt;</A> wrote in =
message <A class=3Dmoz-txt-link-freetext =
href=3D"news:bpt682$jka$1@eclipse.org">news:bpt682$jka$1@eclipse.org</A>.=
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Ok. Thanks a lot.
versions)?
</PRE></BLOCKQUOTE><PRE wrap=3D""><!---->
could
process,
</PRE></BLOCKQUOTE>
<DIV>Well, it was a really easy way to install things.... and the =
platform=20
asked you to validate the installation or decline it (as it seems it =
is doing=20
now by default). I don't know. I think it is a matter of likes.... and =
I was=20
used to the other way.<BR><BR>So theoretically, is this going to be =
the new=20
way to work? Or is it a bug?<BR><BR>Thanks for your=20
comments,<BR><BR>&nbsp;&nbsp;&nbsp;&nbsp;=20
Chemi.</DIV></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_009C_01C3B2DC.96123230--
Re: Problem installing plugins on R3.0 M5 [message #161433 is a reply to message #161371] Tue, 25 November 2003 02:52 Go to previous messageGo to next message
--------------090301050806070300030300
Ok. If you are investigating already, I understand it exists already an
opened bug. Do you mind to send me the URL?
Thanks again,
Chemi.
<html>
<head>
<title></title>
</head>
opened bug. Do you mind to send me the URL?<br>
<br>
Thanks again,<br>
<br>
<br>
<blockquote type="cite" cite="midbpuj3i$695$1@eclipse.org">
<title></title>
<meta name="GENERATOR" content="MSHTML 6.00.2800.1276">
<style></style>
<div><font size="2" face="Arial">Currently it is a bug introduced by
RCP, or at least it appears so. We are tracking it down.</font></div>
</blockquote>
</body>
</html>
--------------090301050806070300030300--
Re: Problem installing plugins on R3.0 M5 [message #161649 is a reply to message #161433] Tue, 25 November 2003 13:47 Go to previous messageGo to next message
------=_NextPart_000_00C0_01C3B35A.A9141500
https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D47458
news:bpv1ug$hf2$1@eclipse.org...
Ok. If you are investigating already, I understand it exists already =
an opened bug. Do you mind to send me the URL?
Thanks again,
Chemi.
Currently it is a bug introduced by RCP, or at least it appears so. =
<META content=3D"MSHTML 6.00.2800.1276" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2><A=20
href=3D"https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D47458">https://bu=
gs.eclipse.org/bugs/show_bug.cgi?id=3D47458</A></FONT></DIV >
<BLOCKQUOTE dir=3Dltr=20
href=3D"news:bpv1ug$hf2$1@eclipse.org">news:bpv1ug$hf2$1@eclipse.org</A>.=
...</DIV>Ok.=20
If you are investigating already, I understand it exists already an =
opened=20
bug. Do you mind to send me the URL?<BR><BR>Thanks=20
again,<BR><BR>&nbsp;&nbsp;&nbsp;&nbsp; Chemi.<BR><BR>dorian birsan =
wrote:<BR>
<BLOCKQUOTE cite=3Dmidbpuj3i$695$1@eclipse.org type=3D"cite">
<STYLE></STYLE>
RCP, or at=20
least it appears so. We are tracking it=20
down.</FONT></DIV></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML >
------=_NextPart_000_00C0_01C3B35A.A9141500--
Re: Problem installing plugins on R3.0 M5 [message #174223 is a reply to message #161649] Sun, 28 December 2003 05:05 Go to previous message
--------------010603080107020705000104
Hi Dorian, that entry said it was fixed on M6 but I am seeing exactly
the same problem.
Any update? Have you decided to change the way installation via file
system works?
Thanks in advance,
Chemi.
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=47458
> "Chemi" <jmordax@terra.es <mailto:jmordax@terra.es>> wrote in
> message news:bpv1ug$hf2$1@eclipse.org...
> already an opened bug. Do you mind to send me the URL?
> Thanks again,
> Chemi.
<html>
<head>
<title></title>
</head>
the same problem.<br>
<br>
system works?<br>
<br>
Thanks in advance,<br>
<br>
<br>
<blockquote type="cite" cite="midbq07vk$2qb$1@eclipse.org">
<title></title>
<div><font size="2" face="Arial"><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=47458">https://bugs.eclipse.org/bugs/show_bug.cgi?id=47458</a></font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;"
dir="ltr">
<div>"Chemi" &lt;<a href="mailto:jmordax@terra.es">jmordax@terra.es</a>&gt;
wrote in message <a href="news:bpv1ug$hf2$1@eclipse.org">news:bpv1ug$hf2$1@eclipse.org</a>...</div>
<br>
Thanks again,<br>
<br>
<br>
<style></style>
by RCP, or at least it appears so. We are tracking it down.</font></div>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------010603080107020705000104--
Previous Topic:JDK1.5.0 download link
Next Topic:[ANN]: eclipse-games 3.0M4 released
Current Time: Tue Jul 15 03:40:56 EDT 2025
Powered by FUDForum. Page generated in 0.28764 seconds
