Home » Archived » BIRT » birt $NO-RB$ org.eclipse.birt.chart.device.swt.SwtRendererImpl
birt $NO-RB$ org.eclipse.birt.chart.device.swt.SwtRendererImpl [message #160738] Sat, 13 May 2006 03:49 Go to next message
i am getting following error
May 13, 2006 1:13:12 PM org.eclipse.birt.chart.exception.ChartException
logThis
SEVERE: Exception
org.eclipse.birt.chart.exception.ChartException: $NO-RB$
org.eclipse.birt.chart.util.PluginSettings.newInstance(Plugi nSettings.java:712)
org.eclipse.birt.chart.util.PluginSettings.getDevice(PluginS ettings.java:403)
at chartPack.ChartViewerTest.<init>(ChartViewerTest.java:120)
at chartPack.ChartViewerTest.main(ChartViewerTest.java:83)
Caused by: java.lang.ClassNotFoundException:
at java.net.URLClassLoader$1.run(URLClassLoader.java:199)
at java.net.URLClassLoader.findClass(URLClassLoader.java:187)
at java.lang.ClassLoader.loadClass(ClassLoader.java:289)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:274 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:141)
org.eclipse.birt.chart.util.PluginSettings.newInstance(Plugi nSettings.java:707)
Re: birt $NO-RB$ org.eclipse.birt.chart.device.swt.SwtRendererImpl [message #160884 is a reply to message #160738] Mon, 15 May 2006 04:39 Go to previous message
Did you get the chart swt plugin? If you did, what version of BIRT are you
using? How do you use the chart, in a report, outside a report?
David
"nitin kumar" <nitinkr11@rediffmail.com> wrote in message
news:d07225678438de93c32144b2c5aa28fc$1@www.eclipse.org...
> logThis
> SEVERE: Exception
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
Previous Topic:refresh/update a chart continuously
Next Topic:why the help text of parameters doesn't display in the web viewer?
Current Time: Sat Sep 06 12:33:46 EDT 2025
Powered by FUDForum. Page generated in 0.03521 seconds
