Home » Modeling » GMF (Graphical Modeling Framework) » Custom Celleditor in gmf TWO
Custom Celleditor in gmf TWO [message #160731] Thu, 15 November 2007 10:38 Go to next message
It's weeks I'm trying with all the example fragments I found, all of the
answers on this forum about customizing celleditors under gmf2 but no one
worked.
Is there a way to replace the celleditor or not in gmf2, in my custom tabs?
Please have the merci not to answer "use search button", there is nothing
but info working good but only on old gmf1.
Re: Custom Celleditor in gmf TWO [message #160824 is a reply to message #160731] Fri, 16 November 2007 02:31 Go to previous messageGo to next message
Originally posted by: marsha.rohrer.swisscom.com
I'm not sure if this helps you because I don't use custom tabs but I
integrated a custom cell editor with GMF 2.0
In your XXXPropertySection#getPropertySource() create a new instance of
your CustomizedPropertySource. The createPropertySoruce() method of this
CostomizedProtpertySource returns a CustomizedPropertyDescriptor. The
method createPropertyEcitor() will then create your customized celleditor.
Hope that helps.
Marsha
Here the code of my CustomizedPropertyDescritpor:
public class CustomizedPropertyDescriptor extends PropertyDescriptor {
public CustomizedPropertyDescriptor(Object object,
IItemPropertyDescriptor itemPropertyDescriptor) {
super(object, itemPropertyDescriptor);
public CellEditor createPropertyEditor(Composite composite) {
CellEditor result = super.createPropertyEditor(composite);
if (result == null)
return result;
EClassifier eType = ((EStructuralFeature) itemPropertyDescriptor
.getFeature(object)).getEType();
if (object instanceof Activity) {
if (eType instanceof EDataType) {
EDataType eDataType = (EDataType) eType;
if (eDataType.getInstanceClass() == String.class) {
result = new ExtendedDialogCellEditor(composite,
getEditLabelProvider()) {
protected Object openDialogBox(Control cellEditorWindow) {
ActivitySelectionDialog dialog = new ActivitySelectionDialog(
cellEditorWindow.getShell(),
cellEditorWindow.getParent());
dialog.create();
if (dialog.open() == Window.OK) {
Object dialogResult = dialog.getResult()[0];
if (dialogResult instanceof ActivityFunctionWrapper) {
ActivityFunctionWrapper wrap = (ActivityFunctionWrapper)
dialogResult;
String res = wrap.getActivity()
.getActivityName()
+ wrap.getFunction()
.getFunctionName();
return res;
return null;
return null;
if (object instanceof Flow) {
FlowSelectionDialog dialog = new FlowSelectionDialog(
cellEditorWindow.getShell());
dialog.create();
if (dialogResult instanceof FlowReference) {
FlowReference flow = (FlowReference) dialogResult;
String res = flow.getFlowName() + ":"
+ flow.getVersion();
return res;
return null;
return null;
return result;
> worked.
Re: Custom Celleditor in gmf TWO [message #160856 is a reply to message #160824] Fri, 16 November 2007 05:28 Go to previous messageGo to next message
Marsha wrote:
> Hope that helps.
> Marsha
> if (result == null)
> return result;
> dialog.create();
> dialogResult;
> .getActivityName()
> .getFunctionName();
> return res;
> return null;
> return null;
> dialog.create();
> return res;
> return null;
> return null;
> return result;
>> worked.
hi! this will be useful, however, how do I hook this
new CustomizedPropertySource(object, ips);
in my
(XXX.diagram.components.sheet.) JunkPropertySection?
this method has this getpropertysource (generated)
* @generated
public IPropertySource getPropertySource(Object object) {
if (object instanceof IPropertySource) {
return (IPropertySource) object;
AdapterFactory af = getAdapterFactory(object);
if (af != null) {
IItemPropertySource ips = (IItemPropertySource) af.adapt(object,
IItemPropertySource.class);
if (ips != null) {
return new PropertySource(object, ips);
if (object instanceof IAdaptable) {
return (IPropertySource) ((IAdaptable) object)
.getAdapter(IPropertySource.class);
return null;
I'm triying to inserting my overrides but they are not read. because if I
replace up there the line:
with
return new CustomizedPropertySource(object, ips);
(and I provide a whatever code for CustomizedPropertySource) the
autogenerated code does not include any "createPropertySoruce", and if I
insert it by hand, won't be read. As I try to scramble a bit to force it
to start, I only mess up with constructors parameters missing or not
compatible.
So, what code did you do to link your ComponentPropertySection.java to
your CustomizedPropertyDescriptor.java??
Re: Custom Celleditor in gmf TWO [message #161978 is a reply to message #160856] Thu, 22 November 2007 01:36 Go to previous message
> Marsha wrote:
>> Hope that helps.
>> Regards,
>> Marsha
>> if (result == null)
>> return result;
>> dialog.create();
>> dialogResult;
>> .getActivityName()
>> .getFunctionName();
>> return res;
>> return null;
>> return null;
>> dialog.create();
>> return res;
>> return null;
>> return null;
>> return result;
>>> worked.
> in my
> * @generated
> if (af != null) {
> if (ips != null) {
> return null;
> with
> compatible.
> Thanks
Hi Paolo,
You are right. In your XXXPropertySection#getPropertySource() you just
have to return your CustomizedPropertySource instead of the PropertySource:
if (af != null) {
if (ips != null) {
//customization
//return new PropertySource(object, ips);
//customization end
return null;
In your CustomizedPropertySource you need to override the
createPropertyDescriptor() method which returns your
CustomizedPropertyDescriptor():
public class CustomizedPropertySource extends PropertySource {
public CustomizedPropertySource(Object object,
IItemPropertySource itemPropertySource) {
super(object, itemPropertySource);
protected IPropertyDescriptor createPropertyDescriptor(
return new CustomizedPropertyDescriptor(object,
You can find a copy of my CustomizedPropertyDescriptor in my first post.
Like this it should work, at least it does in my case.
Marsha
Previous Topic:How to add a name to a connection in the diagram?
Next Topic:command execution in a property update dialog
Current Time: Fri Jul 25 01:51:26 EDT 2025
Powered by FUDForum. Page generated in 0.07674 seconds
