Home » Archived » BIRT » Missed first row of a fixed length file without column name
Missed first row of a fixed length file without column name [message #160665] Fri, 12 May 2006 11:04 Go to next message
Originally posted by: Pasquale.Rombola.ip-assistance.com
I have a problem with a fixed length file (flat file) without column name.
BIRT get first row as column name but it isn't, so I miss first row in
report. How can I get first row ?
Regards and thanks in advance.
Pasquale
Re: Missed first row of a fixed length file without column name [message #161138 is a reply to message #160665] Mon, 15 May 2006 14:48 Go to previous messageGo to next message
hi. i didn't had this problem. can you detail a little bit more your
situation please?
Cristian
Re: Missed first row of a fixed length file without column name [message #161300 is a reply to message #161138] Tue, 16 May 2006 03:34 Go to previous messageGo to next message
Hi Cristian, first of all thanks for your answer to my question, now I'll
try to show you my problem.
I have a fixed length file as data source, that is composed by many rows
of characters like below:
DEND21060504399399210603EUR02148.06.001399
DEND21060504399399210603EUR02148.06.001400
DEND21060504399399210603EUR02148.06.001401
DEND21060504399399210603EUR02148.06.001402
I create Data Source and Data Set without any problem but when I put Data
Set in my report I see all rows less the first row, i.e. I see in report
this:
As you can see first row is missing, indeed BIRT use first row as column
name but it isn't, in my file not exist colunm name but only data. I tried
to get column name in different ways without success. Do you know the
solution or have you any idea to resolve the problem ?
Pasquale
Re: Missed first row of a fixed length file without column name [message #161407 is a reply to message #161300] Tue, 16 May 2006 09:19 Go to previous messageGo to next message
what data source do you use?
Re: Missed first row of a fixed length file without column name [message #161446 is a reply to message #161407] Tue, 16 May 2006 10:15 Go to previous messageGo to next message
I use "Flat File Data Source", then I select a folder that contains a txt
file (data file), while charset is "UTF-8" (default charset). Therefore I
create a Data Set using the Data Source just created and Data Set Type:
"Flat File Data Set", so I select the data file with "*.txt" File filter.
Re: Missed first row of a fixed length file without column name [message #161473 is a reply to message #161446] Tue, 16 May 2006 10:25 Go to previous messageGo to next message
try to use a dummy data as the first row
Re: Missed first row of a fixed length file without column name [message #161501 is a reply to message #161473] Tue, 16 May 2006 11:02 Go to previous messageGo to next message
That was simplest solution by me rejected because all times I have to open
the data file for insert a dummy row and that isn't fine, furthermore it's
boring. It would be necessary to insert a checkbox (enhancement) in Data
Set Properties with label: "First row has column names". As far as you are
concerned that enhancement is expected in future release?
Re: Missed first row of a fixed length file without column name [message #161509 is a reply to message #161501] Tue, 16 May 2006 11:09 Go to previous message
sorry, but I'm not part of the BIRT team. I'm a BIRT user.
Previous Topic:need help - How-to with Birt 2.1RC2
Next Topic:Chart Engine problem (after upgrading to Fedora Core 5).
Current Time: Thu Nov 06 09:47:03 EST 2025
Powered by FUDForum. Page generated in 0.06865 seconds
