Home » Eclipse Projects » Eclipse Platform » Eclipse Startup Memory
Eclipse Startup Memory [message #160527] Sat, 22 November 2003 13:18 Go to next message
Originally posted by: lukas.REMOVE-somnia.com
Hi all,
Is there any way to control the heap/stack sizes for the Eclipse Platform on
startup? I'm running Windows XP with Eclipse 2.1, and would like for
Eclipse to utilize more memory than it is trying to. (Un)fortunately,
Eclipse uses an EXE in this version, and I can't find a way to manually exit
the JVM startup options.
Thanks for any help.
Lukas
Re: Eclipse Startup Memory [message #160585 is a reply to message #160527] Sat, 22 November 2003 15:27 Go to previous message
for example use:
eclipse.exe <args> -vmargs -Xmx512m
Notice that "-vmargs" must be the last argument on the command line.
Genady
Lukas Bradley wrote:
> Hi all,
> Lukas
Previous Topic:Global Actions for Properties View
Next Topic:Code for "Replace with latest from Head"
Current Time: Wed Nov 19 05:37:47 EST 2025
Powered by FUDForum. Page generated in 0.03733 seconds
