could one EditPart have two ContentPane? [message #160500] |
Mon, 06 December 2004 07:29  |
Originally posted by: lin_tower.hotmail.com
When drawing UML class diagram, the diagram will have two contentPane, one
for putting attributes, the othe for operations. Could one EditPart have
two contentpane and put different model type into the contentpane?How to
implement like that class diagram?
Thanks.
lee
Re: could one EditPart have two ContentPane? [message #160515 is a reply to message #160500] |
Mon, 06 December 2004 09:49   |
> Thanks.
> lee
Probably the most GEF friendly way would be for the UML class to have
its own editpart. And the UML class will contain 2 children editparts.
The UML class editpart will layout those children appropriately. 1
child would be an editpart that contained a attribute model, the other
child would be an editpart that contained a operations model.
That is how I would do it for the most compatibility with GEF. But
certainly if you want to create a new figure type, that is an option.
Especially if it will _always_ look the same it would probably be
simpler in the long run.
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber."
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: could one EditPart have two ContentPane? [message #160826 is a reply to message #160719] |
Tue, 07 December 2004 11:19  |
Please remove the bogus color references manually. It will be fixed
shortly.
"lee" <lin_tower@hotmail.com> wrote in message
news:cp36nn$mlu$1@www.eclipse.org...
> I have got the org.eclipse.gef.examples.ediagram project from CVS, but it
> can't compile with GEF 3.0.1. is that project depended on GEF 3.1?
> Randy Hudson wrote:
> > There is a class EditPart in the new ediagram example. You can load
this
> > example from CVS, and it requires EMF. See the GEF FAQ for info on
loading
> > from CVS.
> > The solution we use is to create 2 children "feature parts" for both the
> > operations and attributes features. They have the same model as the
parent
> > editpart. The feature panes are *not* selectable, only their children
are.
> > news:cp1j3a$knt$1@www.eclipse.org...
one
have
to
> >> Thanks.
> >> lee
FUDForum. Page generated in 0.03278 seconds
