| addsDataSetParametersPage [message #160427] |
Thu, 11 May 2006 14:14 |
Originally posted by: dolphycj.xxxxxxxxx.com
I've created a JNDI data source plugin, however, the parameters page for a
dataset doesn't show up in the designer. I am trying to reuse the JDBC
data set. Here's the plugin file for the ui plugin:
<?eclipse version="3.0"?>
<plugin
id="org.eclipse.birt.report.data.oda.jndi.ui"
name="JNDI Data Source UI Plug-in"
version="0.1.0"
provider-name=""
class=" org.eclipse.birt.report.data.oda.jndi.ui.plugin.JndiDSPlugin ">
<runtime>
<library name="oda-jndi-ui.jar">
<export name="*"/>
</library>
</runtime>
<requires>
<import plugin="org.eclipse.birt.core"/>
<import plugin="org.eclipse.birt.report.model"/>
<import plugin="org.eclipse.birt.report.data.oda.jndi"/>
<import plugin="org.eclipse.birt.report.data.oda.jdbc.ui"/>
<import plugin="org.eclipse.birt.report.designer.ui"/>
<import plugin="org.eclipse.jface"/>
<import plugin="org.eclipse.datatools.connectivity.oda"/>
</requires>
<extension
point="org.eclipse.birt.report.designer.ui.odadatasource">
<odaDataSourceUI id="org.eclipse.birt.report.data.oda.jndi">
<newDataSourceWizard
class=" org.eclipse.birt.report.data.oda.jndi.ui.wizards.JndiDataSou rceWizard "/>
<dataSourceEditorPage
class=" org.eclipse.birt.report.data.oda.jndi.ui.wizards.JndiDataSou rcePage "
path="/"
displayName="%datasource.editor.page.connection"
name=" org.eclipse.birt.report.data.oda.jndi.ui.data-source-editor. connection "/>
</odaDataSourceUI>
<odaDataSetUI
id="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
addsDataSetParametersPage="true">
<dataSetEditorPage
class=" org.eclipse.birt.report.data.oda.jdbc.ui.editors.SQLDataSetE ditorPage "
path="/"
displayName="%dataset.editor.page.query"
name=" org.eclipse.birt.report.data.oda.jdbc.ui.data-set-editor-pag e1 "/>
</odaDataSetUI>
<odaDataSetUI
id="org.eclipse.birt.report.data.oda.jdbc.SPSelectDataSet"
<dataSetEditorPage
path="/"
</odaDataSetUI>
</extension>
</plugin>
FUDForum. Page generated in 0.24764 seconds
