Home » Newcomers » Newcomers » Eclipse 3.1.2 does not save JUnit 4.1 preference
Eclipse 3.1.2 does not save JUnit 4.1 preference [message #160307] Tue, 11 July 2006 11:36 Go to next message
Originally posted by: henryc.nortel.com
I am successfully using JUnit4.1 with Eclipse 3.1.2 with the following
annoyance: Each time I start Eclipse, I need to set the JUnit preference to
the JUnit 4.1 installation path.
eg:
Window-Preferences-Java-Build Path-Classpath Variables:
from JUNIT_HOME d:/Program Files/eclipse/plugins/org.junit_3.8.1
to JUNIT_HOME D:/JUnit/junit4.1
It seems that the preference is not being saved at Eclipse shutdown. Any
help is greatly appreciated.
Henry
Re: Eclipse 3.1.2 does not save JUnit 4.1 preference [message #161204 is a reply to message #160307] Mon, 17 July 2006 05:43 Go to previous message
Sorry, that's the way the JUnit classpath variables work; they are
initialized on startup and are not supposed to be changed by the user.
Workarounds:
(A) Update to Eclipse 3.2, which provides a built-in JUnit4 classpath
container (Project Properties > Javav Build Path > Libraries > Add
Library...).
(B) Define your own classpath variable (e.g. JUNIT4_HOME) and use that
one in your test projects.
(C) Add the JUnit4 jar directly on your classpath (or put it into its
own project and make your test projects depend on it).
HTH,
Markus
> eg:
> Henry
Previous Topic:Font Sizes in Eclipse
Next Topic:eclipse 3.2 much heavier than 3.1.2?
Current Time: Sat Jul 19 10:11:05 EDT 2025
Powered by FUDForum. Page generated in 0.07722 seconds
