Home » Newcomers » Newcomers » what is jface ?
what is jface ? [message #160232] Tue, 11 July 2006 04:49 Go to next message
Originally posted by: fhoerni.sopragroup.com
hello
I have an error:
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/uml2/util/UML2AdapterFactory
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
... etc ...
what is JFACE ? which feature/topic/project is it part of ?
I want to download a newer version. It may correct my problem.
thank you.
Frederic Hoerni
Re: what is jface ? [message #160248 is a reply to message #160232] Tue, 11 July 2006 09:06 Go to previous message
Originally posted by: wayne.beaton._NOSPAM_eclipse.org
Frederic Hoerni wrote:
> hello
> I have an error:
> !STACK 0
> ... etc ...
> thank you.
> Frederic Hoerni
JFace is a GUI layer that provides relatively high-level abstractions of
the underlying widget layer. It's part of the base Eclipse installation.
However, I don't think it's the problem. I'm guessing that some JFace
code is trying to load something else and failing. Can you post the
stack trace from the workspace/.metadata/.log file?
Wayne
Previous Topic:Problem with creating an EJB Project
Next Topic:Error Removing Project
Current Time: Sun Nov 02 11:39:53 EST 2025
Powered by FUDForum. Page generated in 0.09031 seconds
