Home » Language IDEs » Java Development Tools (JDT) » The active editor does not contain a main type.
The active editor does not contain a main type. [message #160172] Sun, 23 May 2004 15:29 Go to next message
Originally posted by: dhealy.houston.rr.com
I get this message when I try to run or debug as Java Application. I do
have a main method in the source showing in the editor pane. This is a new
problem with this application. I have been running this application from
the Eclipse Platform for several months.
How do I determine what the active editor is? Is there something else I am
missing?
I am using:
Eclipse Platform Version 2.1.3, Build ID 200403101828.
Dan H.
Re: The active editor does not contain a main type. [message #160455 is a reply to message #160172] Mon, 24 May 2004 17:47 Go to previous message
Originally posted by: smesh.openrules.com
From the source code: *active editor* message you receive in 2.1.X when
you use "Run/Debug" when the focus is in the editor window.
Whan the focus is in the Navigator, you'll receive *selection* in the
message.
Sam Mesh - http://openrules.com
Previous Topic:Cheetah 0.5 and enhanced for loops
Next Topic:Getting notifications for Job.cancel()
Current Time: Mon Sep 01 00:29:59 EDT 2025
Powered by FUDForum. Page generated in 0.02835 seconds
