Home » Language IDEs » C / C++ IDE (CDT) » Does CDT support the docmentation auto generation?
Does CDT support the docmentation auto generation? [message #160038] Thu, 08 December 2005 06:19 Go to next message
I mean, generate the docmentation from the c/c++ code, like the javadoc?
Re: Does CDT support the docmentation auto generation? [message #160136 is a reply to message #160038] Fri, 09 December 2005 01:08 Go to previous message
If you have Doxygen installed, then you can install the Doxygen plugin for
Eclipse and use it to automatically generate documentation, like javadoc
does for Java programs. The plug-in is called Eclox, can be found at
http://home.gna.org/eclox/.
Hope that helps.
Previous Topic:CDT and debugging multi-threaded program
Next Topic:Why can't I use format?
Current Time: Sat Sep 06 09:50:42 EDT 2025
Powered by FUDForum. Page generated in 0.03776 seconds
