Home » Eclipse Projects » Eclipse Platform » Problems building nightly CVS fetch
Problems building nightly CVS fetch [message #160010] Fri, 21 November 2003 07:39
Originally posted by: malte.countnumber.de
I'm having problems building the nightly CVS fetch of Eclipse.
I'm using Linux on a x86 architecture. To be precise:
malte@fuchur:~> uname -a
Linux fuchur 2.4.20-4GB-athlon #1 Wed Aug 6 18:27:52 UTC 2003 i686 unkno=
wn =
unknown GNU/Linux
I have:
* Ant 1.6beta2
* Java 2 SDK 1.4.2_01
* CVS 1.11.5
* 6685860 bytes of free space (~ 6.7 gig)
When I tried to run this:
fuchur:~/arc/eclipse/buildScripts # ./build -os linux -ws gtk -arch x86
It did all sort of things for a while, and then exited with:
build.jars:
properties:
init:
build.sources:
properties:
init:
pdeuisrc.zip:
BUILD FAILED
/root/arc/eclipse/buildScripts/plugins/org.eclipse.pde.ui/bu ild.xml:68: =
/root/arc/eclipse/buildScripts/plugins/org.eclipse.pde.ui/sa ndbox not =
found.
Total time: 30 minutes 22 seconds
Then I tried to use motif instead of gtk (I removed the previous =
buildScripts/ directory first and unpacked a new one):
fuchur:~/arc/eclipse/buildScripts # ./build -os linux -ws motif -arch x8=
6
But I got the same error after a while:
build.jars:
properties:
init:
build.sources:
properties:
init:
pdeuisrc.zip:
BUILD FAILED
found.
Total time: 28 minutes 47 seconds
I searched for this error with Google and on eclipse.org, but I couldn't=
find that problem mentioned anywhere, so this is why I'm asking here :-)=
Now that I write this mail, I note that I do not have motif-devel =
installed. Is this necessary to build eclipse with motif? Note that I ha=
ve =
motif installed, though. I do have gtk, gtk-devel, gtk2, and gtk2-devel,=
also, so I don't think installing motif-devel would solve the problem =
anyways.
I was using eclipse-sourceBuild-srcFetch-N20031118.zip when I did all =
this. I see there is a newer version now, but I guess that's not the =
problem either.
Any help would be highly appreciated!
Greetings,
Malte
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
Previous Topic:No clean refactoring
Next Topic:Adding Javadoc to a public static final variable
Current Time: Thu Jul 17 06:04:05 EDT 2025
Powered by FUDForum. Page generated in 0.19165 seconds
