Home » Language IDEs » Java Development Tools (JDT) » Finding all methods having 0 references
Finding all methods having 0 references [message #159705] Thu, 20 May 2004 14:53 Go to next message
My team has recently taken over a new code base, and we're looking for all
methods that have zero references in the code base. Is there a quick way
to get a list of all of these, or does one need to go method by method and
check for references? I've looked in the help and different menu options,
but didn't find a way to do this. Thanks for any suggestions.
--Gary
Re: Finding all methods having 0 references [message #159717 is a reply to message #159705] Thu, 20 May 2004 17:59 Go to previous messageGo to next message
I think there is an option to mark unused private methods as warnings.
I don't think there is such option for other methods. Also public
methods may be
used by reflection, which makes such search inaccurate.
Genady
Genady Beryozkin
http://www.genady.net/
>--Gary
Re: Finding all methods having 0 references [message #159722 is a reply to message #159705] Thu, 20 May 2004 17:21 Go to previous messageGo to next message
You may be able to use this plugin to do what you want:
http://www.cs.ubc.ca/labs/spl/projects/jquery/
JQuery is a flexible, query-based source code browser, developed as an
Eclipse plug-in. After selecting a java working set of interest, a JQuery
user can define his or her own top-level queries (or "browsers")
on-the-fly by formulating logic queries and running them against his/her
source code.
Matt
Re: Finding all methods having 0 references [message #159725 is a reply to message #159717] Thu, 20 May 2004 17:25 Go to previous messageGo to next message
Genady,
Thanks for the tip. We had considered the possibility of reflective
calls, and that's not being done in this application. Unfortunately, most
of the methods are public, so the filter won't help too much, but it will
help some. ;-)
--Gary
> methods may be
> Genady
> Genady Beryozkin
> >--Gary
Re: Finding all methods having 0 references [message #160198 is a reply to message #159722] Sun, 23 May 2004 23:07 Go to previous message
Matt,
I hadn't heard of JQuery before, but it looks interesting. I'll read up
on it and see if I can use it. Thanks for the tip.
--Gary
> source code.
> Matt
Previous Topic:JVM SWING
Next Topic:Shift+Ctl+F
Current Time: Sat Nov 22 09:07:47 EST 2025
Powered by FUDForum. Page generated in 0.02704 seconds
