Does not support port monitoring [message #159699] |
Wed, 08 February 2006 16:34  |
I'm working with:
Eclipse 3.1
Tomcat 5.5.15
Axis 1_2_1
Java JDK 1.5
I just recently changed from older versions:
Tomcat 5.0.25
Axis 1_1
Java SDK 1.4
I wanted to upgrade to JDK 1.5 to work with "enums" that required that I
upgrade to Axis 1_2_1 or 1_3. I originally upgraded to 1_3 but backed up
to 1_2 because I noticed that within the Eclipse plugins there was a
org.apache.axis_1.2.1 and I thought it best to be consistent.
Since making these changes I have noticed a few errors that I had not seen
with the previous versions:
When I go to generate the Web Service from the WSDL. I choose new Web
Service as the option and of the check boxes on the first window I select
the following:
Top down Java bean Web Service
Start Web service in Web project
Monitor the Web Service
Overwrite files without warning
Create folders when necessary
These are the same options I have always selected and for the rest of the
windows I don't do anything differently.
Now I get an error message:
IWAB0002I Tomcat v5.5 Server @ localhost does not support port monitoring.
I did not get this before and cannot find any information. Can someone
please help.
Ben
FUDForum. Page generated in 0.03457 seconds
