Home » Newcomers » Newcomers » Eclipse v2.0 - Annoying dialog box
Eclipse v2.0 - Annoying dialog box [message #159682] Wed, 05 July 2006 16:31 Go to next message
Originally posted by: news.redbandsystems.com
I installed Eclipse 2.0 with CDT v3.0.2. I now get a dialog
box "Error notifying a preference change listener. Check log
for details". After typing hundreds of returns, I can finally
get to the log. In the log, I see
eclipse.buildId=M20060629-1905
java.version=1.4.2_06
Command-line arguments: -os win32 -ws win32 -arch x86
This is a continuation of log file
C:\Home\abiyani\etc\eclipse\.metadata\.bak_1.log
Created Time: 2006-07-05 13:24:19.779
Warning
Wed Jul 05 13:24:21 PDT 2006
'class org.eclipse.cdt.internal.ui.editor.CDocumentSetupParticipant '
must not install a default partitioner.
Error
Wed Jul 05 13:24:20 PDT 2006
Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
org.eclipse.cdt.internal.ui.text.CTextTools.adaptToPreferenc eChange(CTextTools.java:238)
org.eclipse.cdt.internal.ui.text.CTextTools$PreferenceListen er.propertyChange(CTextTools.java:38)
org.eclipse.ui.preferences.ScopedPreferenceStore$3.run(Scope dPreferenceStore.java:372)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.ui.preferences.ScopedPreferenceStore.firePropert yChangeEvent(ScopedPreferenceStore.java:369)
org.eclipse.ui.preferences.ScopedPreferenceStore.setToDefaul t(ScopedPreferenceStore.java:663)
org.eclipse.cdt.ui.CUIPreferenceInitializer.useTextEditorPre ferencePage(CUIPreferenceInitializer.java:84)
org.eclipse.cdt.ui.CUIPreferenceInitializer.initializeDefaul tPreferences(CUIPreferenceInitializer.java:51)
org.eclipse.core.internal.preferences.PreferenceServiceRegis tryHelper.runInitializer(PreferenceServiceRegistryHelper.jav a:276)
org.eclipse.core.internal.preferences.PreferenceServiceRegis tryHelper.applyRuntimeDefaults(PreferenceServiceRegistryHelp er.java:130)
org.eclipse.core.internal.preferences.PreferencesService.app lyRuntimeDefaults(PreferencesService.java:337)
org.eclipse.core.internal.preferences.DefaultPreferences.app lyRuntimeDefaults(DefaultPreferences.java:162)
org.eclipse.core.internal.preferences.DefaultPreferences.loa dDefaults(DefaultPreferences.java:231)
org.eclipse.core.internal.preferences.DefaultPreferences.loa d(DefaultPreferences.java:227)
org.eclipse.core.internal.preferences.EclipsePreferences.cre ate(EclipsePreferences.java:307)
org.eclipse.core.internal.preferences.EclipsePreferences.int ernalNode(EclipsePreferences.java:543)
org.eclipse.core.internal.preferences.EclipsePreferences.nod e(EclipsePreferences.java:662)
org.eclipse.core.internal.preferences.AbstractScope.getNode( AbstractScope.java:38)
org.eclipse.core.runtime.preferences.DefaultScope.getNode(De faultScope.java:67)
org.eclipse.ui.preferences.ScopedPreferenceStore.getDefaultP references(ScopedPreferenceStore.java:248)
org.eclipse.ui.preferences.ScopedPreferenceStore.getPreferen ceNodes(ScopedPreferenceStore.java:282)
org.eclipse.ui.preferences.ScopedPreferenceStore.internalGet (ScopedPreferenceStore.java:472)
org.eclipse.ui.preferences.ScopedPreferenceStore.getString(S copedPreferenceStore.java:532)
org.eclipse.jface.preference.PreferenceConverter.getColor(Pr eferenceConverter.java:204)
org.eclipse.cdt.internal.ui.text.AbstractCScanner.addToken(A bstractCScanner.java:96)
org.eclipse.cdt.internal.ui.text.AbstractCScanner.initialize (AbstractCScanner.java:89)
org.eclipse.cdt.internal.ui.text.CCodeScanner.<init>(CCodeScanner.java:59)
at org.eclipse.cdt.internal.ui.text.CTextTools.<init>(CTextTools.java:93)
at org.eclipse.cdt.ui.CUIPlugin.getTextTools(CUIPlugin.java:400 )
org.eclipse.cdt.internal.ui.editor.CEditor.initializeEditor( CEditor.java:225)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.<init >(AbstractDecoratedTextEditor.java:269)
at org.eclipse.ui.editors.text.TextEditor.<init>(TextEditor.java:51)
at org.eclipse.cdt.internal.ui.editor.CEditor.<init>(CEditor.java:218)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:157)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:242)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:238)
org.eclipse.ui.internal.registry.EditorDescriptor.createEdit or(EditorDescriptor.java:231)
at org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:908)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:549)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1420)
at org.eclipse.ui.internal.EditorManager$5.run(EditorManager.ja va:1005)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:1000)
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2836)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1936)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:2857)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:2 805)
at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1681 )
org.eclipse.ui.internal.Workbench.runStartupWithProgress(Wor kbench.java:1421)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1679)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1 650)
at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1529 )
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1473)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:183)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:702)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1085)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1847)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Please help.
Arun
Re: Eclipse v2.0 - Annoying dialog box [message #159696 is a reply to message #159682] Wed, 05 July 2006 17:56 Go to previous messageGo to next message
Originally posted by: jefmyers.us.ibm.com
You could file a bug report against CDT, but most likely they'll just
suggest that you upgrade to Eclipse 3.2 + CDT 3.1.
- Jeff
Re: Eclipse v2.0 - Annoying dialog box [message #159703 is a reply to message #159696] Wed, 05 July 2006 18:47 Go to previous messageGo to next message
> - Jeff
Apparently, CDT 3.1 is not available yet for download. I tried to
upgrade and there were no updates available. Are you saying, they
will suggest just waiting for it?
Arun
Re: Eclipse v2.0 - Annoying dialog box [message #159709 is a reply to message #159703] Wed, 05 July 2006 20:05 Go to previous messageGo to next message
CDT 3.1 is available for download. It'll only show up in the update
manager if you're running Eclipse 3.2.
- Jeff
Re: Eclipse v2.0 - Annoying dialog box [message #159715 is a reply to message #159709] Wed, 05 July 2006 21:16 Go to previous messageGo to next message
> - Jeff
I am using the link below.
http://download.eclipse.org/tools/cdt/releases/eclipse3.1
I am running eclipse 3.2.0. The update manager still insists that no
updates are available (I have CDT 3.0.2). On their site, the url has
v3.1 but the latest release only seems to be 3.0.2. Could you email
me a url to stick into the update manager?
Thx
Arun
Re: Eclipse v2.0 - Annoying dialog box [message #159721 is a reply to message #159715] Wed, 05 July 2006 21:24 Go to previous messageGo to next message
It's available from the Callisto update site, which should be included
already in your list in 3.2. Select the Callisto Discovery Site, and the
resulting list of plug-ins will contain CDT 3.1.
Hope this helps,
- Jeff
>> - Jeff
> Thx
> Arun
Re: Eclipse v2.0 - Annoying dialog box [message #159776 is a reply to message #159715] Thu, 06 July 2006 09:15 Go to previous message
>> - Jeff
> Thx
> Arun
Thx. Jeff. As you mentioned, the CDT v3.1.0 is on the Callisto Discovery
site. It was disabled in my setup. As soon as I enabled it, I found
the new version. I am updating now.
Arun
Previous Topic:installing 3.2 using Update Manager
Next Topic:Trouble with Navigator
Current Time: Sun Aug 31 12:31:37 EDT 2025
Powered by FUDForum. Page generated in 0.13859 seconds
