Home » Archived » BIRT » Help with XML Driver. (Issue: missing data in reports)
Help with XML Driver. (Issue: missing data in reports) [message #159661] Tue, 09 May 2006 13:04 Go to next message
Originally posted by: rana.vedre.bankofamerica.com
Hi all -
I am using XML ODA driver in my BIRT Report designs for some financial
Reports.
I have chosen XML driver to accommodate storing historical report data
in xml format, instead of building a relational database schema
based on Report numbers/calculations.
Our product is in QA now, and we are finding that some of the data in
the report is not displayed. This is happening randomly about once every 5
times on an average.
We are seeing this behaviour(missing/blank report data) more frequently
in HTML than in PDF format.
I have also tried using the latest version (BIRT 2.1 M2), but still
having the same issues.
Are there any best practices for BIRT XML report mapping, that I can
follow in my report designs(using XML Driver).
Is this a known issue in BIRT XML driver?
I know XML driver is a new Feature in BIRT. Did any of you have
successfully implemented BIRT Reports using XML datasource in your
projects.
-Rana.
Re: Help with XML Driver. (Issue: missing data in reports) [message #159731 is a reply to message #159661] Wed, 10 May 2006 02:49 Go to previous message
Originally posted by: marc.leineweber.icc-gmbh.de
Hello Rana,
I had a similiar problem - data of one field was truncated, and when I put a
shorter text into another field (in the xml data file), the former truncated
became longer by the same number of characters. This is really a weird
behavior but I got a hint from another user for a workaround: Add an XML
element (arbitrary name, empty contents) right before the truncated field -
the truncation seems to be shifted to the unnecessary empty element. In my
case, I only had to do it once, but if you see the problem in more than one
field you probably have to repeat the trick. By the way, I could not see a
difference in HTML / PDF output.
I had a performance problem with my XML data source (I reported a bug to the
BIRT bugzilla yesterday), so I now use a scripted datasource together with
JDom to read the XML file - the perfromance is better and the field
truncation is no issue anymore.
Hope this helps,
Marc
"Rana Vedre" <rana.vedre@bankofamerica.com> schrieb im Newsbeitrag
news:eab8422a5ca8237a579b9c0573f17887$1@www.eclipse.org...
> Hi all -
> Reports.
> I have chosen XML driver to accommodate storing historical report data in
> xml format, instead of building a relational database schema based on
> Our product is in QA now, and we are finding that some of the data in the
> times on an average. We are seeing this behaviour(missing/blank report
> data) more frequently in HTML than in PDF format.
> projects.
> -Rana.
Previous Topic:where to put ODA plugins in Version 2.1
Next Topic:probleam in image in html
Current Time: Fri Jul 18 00:21:53 EDT 2025
Powered by FUDForum. Page generated in 0.25808 seconds
