Home » Language IDEs » Java Development Tools (JDT) » Folder in classpath for java project
Folder in classpath for java project [message #159640] Thu, 20 May 2004 09:01 Go to next message
How can I add folder from file systems in classpath for java project,
programmable (folder can be in eclipse workspace or not) ?
regards
Haris Peco
Re: Folder in classpath for java project [message #159686 is a reply to message #159640] Thu, 20 May 2004 13:39 Go to previous messageGo to next message
hi
first you have to take the actual classpaths:
IClasspathEntry[] oldEntries = javaProject.getRawClasspaths();
then create a new array of IClasspathEntry, but now with capacity for the
new classpath we want to add
IClasspathEntry[] newEntries = new IClasspathEntry[oldEntries.length+2];
System.arrayCopy (oldEntries,0,newEntries,0,oldEntries.length);
newEntries[oldEntries.length]=JavaRuntime.getDefaultJREConta inerEntry();
and then you have to add the path of the folder you want. To create a
IClasspathEntry out of a path you can use:
JavaCore.newSourceEntry
JavaCore.newLibraryEntry
depending on the the kind of classpath you want to create
then have to set the new claspaths:
javaProject.setRawClasspath (newEntries,null);
> Hello,
> regards
> Haris Peco
Re: Folder in classpath for java project [message #159711 is a reply to message #159686] Thu, 20 May 2004 18:34 Go to previous messageGo to next message
I know this and I add easy base source, runtime library and jar libraries
and I want add folder btw:
/home/snpe/classes
When I create IClasspathEntry for this ?
I try
IClasspathEntry entry = JavaCore.newLibraryEntry(new
Path("/home/snpe/classes"),null,null);
but after javaProject.setRawClassPath my src lib,runtime lib and jar libs
are in classpath, but folder path not
Re: Folder in classpath for java project [message #159836 is a reply to message #159711] Fri, 21 May 2004 13:56 Go to previous messageGo to next message
> /home/snpe/classes
> I try
I play with classpath yet - Classpath engine in eclipse try find class in
workspace when path is folder - don't try /home/snpe/classes then
WORKSPACE_HOME/home/snpe/classes (probably need project home too)
It is a problem with test environment - test start in empty workspace and I
have export to jar libraries all dependencies plugins for test project
Is there solution ?
regards
Haris Peco
Re: Folder in classpath for java project [message #160015 is a reply to message #159836] Sat, 22 May 2004 12:36 Go to previous messageGo to next message
You can create a folder in your project linked to the folder you want to
add to the classpath. Then, instead of adding the original folder, add the
linked one.
> Is there solution ?
> regards
> Haris Peco
Re: Folder in classpath for java project [message #160051 is a reply to message #160015] Sat, 22 May 2004 16:26 Go to previous messageGo to next message
Hello Marcos,
I understand - it isn't possible add folder without workspace , but why ?
> linked one.
>> I have export to jar libraries all dependencies plugins for test project
>> Is there solution ?
>> regards
>> Haris Peco
Re: Folder in classpath for java project [message #160082 is a reply to message #160051] Sat, 22 May 2004 18:48 Go to previous message
I think that a bug related to this problem has been posted.
don't know if there's a better solution for this. At least i don't know
it. If you ever find another way, please send me an email telling me how.
> Hello Marcos,
> Thanks
> > linked one.
> >> Is there solution ?
> >> regards
> >> Haris Peco
Previous Topic:Ant 1.6.1
Next Topic:Remote Debugging j2eesdk1.3.1 with Eclipse
Current Time: Wed Nov 19 12:56:20 EST 2025
Powered by FUDForum. Page generated in 0.05426 seconds
