| Error Parser [message #159497] |
Wed, 30 November 2005 13:45  |
Originally posted by: gabriel.phan.ge.com
I'm trying to write an error parser for my compiler which is the Windriver
Diab DCC compiler. Examples of the error output are below. Can some help
me out or point me in the right direction.
All the help that I found online says to create an extension for
org.eclipse.cdt.core.ErrorParser. I have looked through the Eclipse
directory and can not find that directory. I am running ver 3.1.1.
"0181\src\codec.c", line 152: error (dcc:1525): identifier _ALARM_CLEARED
not declared
"0181\src\codec.c", line 152: error (dcc:1633): parse error near
'_ALARM_CLEARED'
"0181\src\codec.c", line 152: error (dcc:1206): syntax error
"0181\src\codec.c", line 152: fatal error (dcc:1340): can't recover from
earlier errors
Gabe
| Re: Error Parser [message #159573 is a reply to message #159497] |
Wed, 30 November 2005 18:26   |
Originally posted by: eclipse.dharty.com
Take a look at
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.cdt-cor e/org.eclipse.cdt.core/src/org/eclipse/cdt/internal/errorpar sers/?cvsroot=Tools_Project#dirlist
for the code to the existing cdt error parsers. You will also want to
look at the plugin.xml file for the existing cdt error parser and binary
parser plugins (extract the .jar files with an archiving utility like
winrar or jar.exe that comes with the java jdk).
To start, create a new plugin project.
When the project is created, click on the "Extensions" of the project
page to add a new extension of the org.eclipse.cdt.core.ErrorParserpoint
extension point. Be sure you connect to this existing extension, don't
try to add/create a new extension point.
You now need to edit the plugin.xml file manually. There should exist
an extension tag that looks like:
<extension
point="org.eclipse.cdt.core.ErrorParser">
</extension>
You will need to add an id attribute, a name attribute, and an
erroparser element that points to the ErrorParser class that you are
going to implement, eg com.mycompany.MyErrorParser:
<extension
id="MyErrorParser"
name="%MyErrorParser.name" <!-- this will be referenced in the
plugin.properties file, don't forget the '%' -->
<errorparser
class="com.mycompany.MyErrorParser">
</errorparser>
</extension>
Now, edit the file plugin.properties an add a line for the ErrorParser
name, but leave out the '%' symbol. eg:
MyErrorParser.name=My Error Parser
Now all thats left is to create the error parser class itself, eg
com.mycompany.MyErrorParser. You can use the plugin framework to run a
debug mode of eclipse to debug your error parsers.
Good Luck,
David
> Windriver Diab DCC compiler. Examples of the error output are below.
> Can some help me out or point me in the right direction.
> _ALARM_CLEARED not declared
> '_ALARM_CLEARED'
> earlier errors
> Gabe
| Re: Error Parser [message #160855 is a reply to message #159497] |
Wed, 21 December 2005 07:35  |
Originally posted by: MCondarelli.harmanbecker.com
did You solve Your problem?
I need the same thing (use diab compiler under eclipse), so, perhaps, we
could help each other...
Mauro
FUDForum. Page generated in 0.04147 seconds
