Home » Language IDEs » Java Development Tools (JDT) » eclipse 3.0 M8 refresh problem
eclipse 3.0 M8 refresh problem [message #159436] Wed, 19 May 2004 07:22 Go to next message
Originally posted by: mar1u50.yahoo.ca
I'm using eclipse to develop a web application. Appears the F5 int he
tree is not working after upgrading to M8.
I also tried to rightmouse and the to choose refresh. In this case
eclipse display a refresh dialog and appears to do something but the
result is still bad.
If I do a CVS-Synchronize with repository, some modified files are
refusing to be displayed as modified.
Also some of the changed jsps are not reflected as modified.
To summary, refresh is not always working. Please note that other 3
developers has the same problem since M8 was released. The eclipse log
does not contain anything usefull.
Any ideea ?
Best Regards
Marius
Re: eclipse 3.0 M8 refresh problem [message #159444 is a reply to message #159436] Wed, 19 May 2004 08:22 Go to previous messageGo to next message
Originally posted by: rndzank.comcast.net.not_this.net
Dear Marius from Yahoo ;)
1. you didn't say which tree you are refreshing
2. are you using any plugins (e.g. web devel.) that do not work
with M8?
Marius OANCEA wrote:
> Hello,
> Any ideea ?
> Best Regards
> Marius
Re: eclipse 3.0 M8 refresh problem [message #159484 is a reply to message #159436] Wed, 19 May 2004 11:27 Go to previous messageGo to next message
> Hello,
> Any ideea ?
> Best Regards
> Marius
F5 is used for refresh and for the Debug Command "Step Into". If you
have any debug sessions running, F5 will not refresh. Actually for a
time F5 would always call Step Into instead of refresh, but this has
been fixed (don't remember if it was fixed pre or post M8 though).
Re: eclipse 3.0 M8 refresh problem [message #159500 is a reply to message #159484] Wed, 19 May 2004 12:43 Go to previous messageGo to next message
F5 for refresh was pretty much broken in M8 from what I remember.
Try a later integration build (the one from this week) or wait and use M9
which is due out at the end of the week(
HTH
Darins
"Kevin Barnes" <krbarnes@ca-dot-ibm.com> wrote in message
news:c8ftv4$ovo$1@eclipse.org...
> > Hello,
> > Any ideea ?
> > Best Regards
> > Marius
Re: eclipse 3.0 M8 refresh problem [message #159741 is a reply to message #159444] Fri, 21 May 2004 03:11 Go to previous messageGo to next message
I try to or package view (Java perspective).
> with M8?
I only use sysdeo tomcat plugin 2.2.1 and lomboz to edit jsps.
That is all.
> > Hello,
> > Any ideea ?
> > Best Regards
> > Marius
Re: eclipse 3.0 M8 refresh problem [message #159743 is a reply to message #159484] Fri, 21 May 2004 03:12 Go to previous messageGo to next message
No debug session is active.
If I delete the content of classes for example, the classes and resources
will not be recreated ever.
> > Hello,
> > Any ideea ?
> > Best Regards
> > Marius
Re: eclipse 3.0 M8 refresh problem [message #159746 is a reply to message #159500] Fri, 21 May 2004 03:13 Go to previous message
I tried a later intergration build but tomcat plugin is not working
anymore :(
> HTH
> Darins
> > > Hello,
> > > Any ideea ?
> > > Best Regards
> > > Marius
Previous Topic:Problem Debugging servlets
Next Topic:Launch configs feature request?
Current Time: Tue Jul 15 06:11:17 EDT 2025
Powered by FUDForum. Page generated in 0.28228 seconds
