Home » Archived » BIRT » java.lang.AssertionError running pdf format, why??
java.lang.AssertionError running pdf format, why?? [message #159433] Tue, 09 May 2006 05:35 Go to next message
when I run the report and the output format set is pdf i get this error:
Error happened while running the report.
org.eclipse.birt.report.engine.layout.area.impl.ContainerAre a.align(ContainerArea.java:261)
org.eclipse.birt.report.engine.layout.area.impl.TableBandAre a.align(TableBandArea.java:256)
org.eclipse.birt.report.engine.layout.impl.TableLayoutManage r.addBand(TableLayoutManager.java:766)
org.eclipse.birt.report.engine.layout.impl.TableLayoutManage r.addArea(TableLayoutManager.java:849)
When the output format is html there is no error.
Does anyone know why?,
Thanks in advance
Re: java.lang.AssertionError running pdf format, why?? [message #159584 is a reply to message #159433] Tue, 09 May 2006 08:43 Go to previous message
I resolved it. It was a conflict between two libraries!
Previous Topic:BIRT report with XML datasource: performance problem
Next Topic:Want to change the filter values at run time
Current Time: Sun Nov 09 01:44:58 EST 2025
Powered by FUDForum. Page generated in 0.03440 seconds
