GEF, EMF and semantic vs. graphical model [message #159319] |
Wed, 24 November 2004 07:46  |
Originally posted by: usenet.jevopi.de
I've followed some of the threads concerning GEF and EMF integration.
I'm glad that other people have the same problems with two
implementations of the Command pattern and other things (e.g. the
naming problem with ConnectionEditPart.getTarget() and
Adapter.getTarget()).
Are there any concrete approches yet integrating these two frameworks?
Frank Budinsky wrotes about a prototyping work with "support for
generating GEF views in a generated EMF editor". I think this would be
very interessting.
IMHO this idea is related to a more general problem: adding graphical
information to domain (or semantic or business) models. The Red Book
mentions three approches solving that problem:
1) Create a modified version of the (domain) model with graphical information
2) Use two separate models
3) "Use modelling techniques" to make a link between the two models
I'm not sure if I understand point 3) since it appears to me as if 1)
and 2) are modelling techniques as well -- and the example given for 3)
seems to me pretty much the same as the frist approach.
I'm wondering if there exists any work about this issue. For example a
generator for GEF views requires at least two information:
a) A mapping from model elements to nodes or connections
b) Information about how to get and set layout constraints
The "UML Diagram Interchage" (UMLDI) is an approach for answering the
question for UM2 models (and maybe others as well). I'm currently
developing a small class diagram using (my own) EMF based
implementation of UMLDI in combination with UML2. I'm running into a
lot of problems with this solution, and I'm wondering if there exist
any work about how to combine domain model and graphical information.
Besides that, I'm not too happy with UMLDI, since the specification
isn't finished yet and too many questions are left unanswered.
Are there any (other) works on that issure? If there are any works on
integrating GEF and EMF, is this a topic there? Do you know samoe
articles about this subject?
Jens
PS: Is it called "semantical model" or "semantic model".. (or graphical
vs. graphic model)? Too many problems everywhere %-)
PPS: Maybe I should have posted this article in the EMF newsgroup, but
I thought it's more a graphical related problem, isn't it?
Re: GEF, EMF and semantic vs. graphical model [message #159970 is a reply to message #159806] |
Wed, 01 December 2004 06:31   |
> You should ask why getTarget is on Adapter. Adapter is the interface used
> *by* the TARGET. Surely the target already knows about itself. If a
> specific adapter needs to allow clients to reach in to the EMF object, that
> adapter should provide the unwrap() method on the interface which the
> adapter is exposing to clients (the actual interface being adapted).
I didn't want to start a discussion about the adapter pattern here :)
I've already posted a message in the EMF newsgroup
(Pattern trouble: Adapter, Observer, Extension Object, Date: Mon, 18
Oct 2004) where I tried to understand the EMF implementation of the
adapter pattern. IMHO Adapter.getTarget() should be called
Adapter.getSubject() (using the observer pattern role name) or
Adapter.getAdaptee() (using the adapter pattern role name). I also
think that the Adapter interface should be splitted into two
interfaces, a NotifierListener (or something) and the Adapter
interface. But I don't think that this interface is going to be
refactored, is it?
> I use the terms "business model" and "view model" . "semantic model" is the
> same as business, but it take me longer to process that term in my head :-P
OK. Since I'm not a native speaker, it makes not difference to me using
"semantic", "domain" or "business" :)
Do you know any works (atricles, patterns) on combining business and
view model?
Maybe it would be a nice idea of creating a, maybe EMF/UMLDI based,
layer (or framework) handling the view model. Using some kind of
mapping mechanism this layer could be connected to the business model
and the EditParts. I'm wondering if it's possible to move all view
model related stuff into this framework and provide some super classes,
e.g. ConstraintChange commands for moving the GraphNodes around.
Jens
Re: GEF, EMF and semantic vs. graphical model [message #160026 is a reply to message #159970] |
Wed, 01 December 2004 12:02  |
I have seen a generic EMF-based diagram model implemented in the past and it
was not successful. I don't know of any ongoing efforts for this type of
work. It doesn't fall under the scope of the GEF project charter. The VE
project might include a base view model like what you are suggesting.
> view model?
> Jens
FUDForum. Page generated in 0.03799 seconds
