Home » Eclipse Projects » Eclipse Platform » 3.0M4 no longer running on Debian Sid
3.0M4 no longer running on Debian Sid [message #159274] Thu, 20 November 2003 03:42 Go to next message
I was using 3.0M4 on Sid for a while without trouble, and recent upgrades
in sid seems to have broken M4 platform build:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x400AEA3E
Function=__libc_free+0x4E
Library=/lib/tls/libc.so.6
Current Java thread:
at java.util.zip.Inflater.end(Native Method)
at java.util.zip.Inflater.end(Inflater.java:294)
- locked <0x447a6570> (a java.util.zip.Inflater)
at java.util.zip.ZipFile.close(ZipFile.java:357)
- locked <0x447a7bd8> (a java.util.Vector)
at java.util.zip.ZipFile.finalize(ZipFile.java:378)
at java.lang.ref.Finalizer.invokeFinalizeMethod(Native Method)
at java.lang.ref.Finalizer.runFinalizer(Finalizer.java:83)
at java.lang.ref.Finalizer.access$100(Finalizer.java:14)
at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:1 60)
Local Time = Thu Nov 20 09:28:26 2003
Elapsed Time = 3
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (Blackdown-1.4.1-01 mixed mode)
/me goes back to 2.1 ..
TTimo
Re: 3.0M4 no longer running on Debian Sid [message #159282 is a reply to message #159274] Thu, 20 November 2003 03:53 Go to previous messageGo to next message
NOTE:
- this *used* to work just fine two days ago
- 2.1 installed from platform zip release exhibits the same error behaviour
- Debian's own 2.1 package works (??)
TTimo
Re: 3.0M4 no longer running on Debian Sid [message #159298 is a reply to message #159282] Thu, 20 November 2003 04:15 Go to previous messageGo to next message
Spoke too fast, this is happening with the debian package also. Opened a
bug item on debian tracker.
TTimo
On Thu, 20 Nov 2003 09:53:19 +0100
Timothee Besset <ttimo@ttimo.net> wrote:
> NOTE:
> TTimo
Re: 3.0M4 no longer running on Debian Sid [message #159382 is a reply to message #159298] Thu, 20 November 2003 08:19 Go to previous messageGo to next message
> TTimo
> > NOTE:
It's working fine on my computer with sun's VM..
Thus I think that eclipse is not guilty but that blackdown's VM is instead
I recommend you not to use it in its later version.
We've run into several blocking issues with it, including non
reproductible /deterministic crashes of eclipse/weblogic.
We now use sun's VM 1.4.2_02 and eclipse works fine.
There may be philosophical reasons not to use sun's VM .. but it works
better with it ;)
Best regards
Jean
> > TTimo
Re: 3.0M4 no longer running on Debian Sid [message #159429 is a reply to message #159382] Thu, 20 November 2003 09:26 Go to previous messageGo to next message
Originally posted by: muelleimer.usenet.katzien.de
Hallo!
I forwarded that to some BD developer. I hope they can shed some light
on this. I suspect some problems with the libc6 threading changes.
I think so too.
I can say the same for IBMs 1.4 JVM.
Jan
Re: 3.0M4 no longer running on Debian Sid [message #159959 is a reply to message #159382] Fri, 21 November 2003 04:32 Go to previous message
I switched to Sun's VM and it's working fine again. Thanks for the tips.
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_02-b03
TTimo
On Thu, 20 Nov 2003 13:19:15 +0000 (UTC)
> > TTimo
> > > NOTE:
> Hello,
> better with it ;)
> Best regards
> Jean
> > > TTimo
Previous Topic:Can't figure out why setEditable() doesn't work
Next Topic:Remote Debugging again
Current Time: Thu Nov 06 05:31:52 EST 2025
Powered by FUDForum. Page generated in 0.07408 seconds
