Home » Modeling » GMF (Graphical Modeling Framework) » Question (Yes/No) for Delete elements
Question (Yes/No) for Delete elements [message #159220] |
Fri, 09 November 2007 06:30  |
Originally posted by: juergen.sterr.brainchild.de
I want warn the user with a message(Yes/No), after the option (Delete from
Model).
It is important to me because it delete the complete tree behind this
element.
Now I look for a way in *BaseItemSemanticEditPolicy.
My question is:
Where can I implement this message?
Which return command? (Null gives an error)
Jürgen
Re: Question (Yes/No) for Delete elements [message #159418 is a reply to message #159410] |
Sat, 10 November 2007 09:03   |
Originally posted by: jan.herriger.gmx.de
--------------010800000008060804030800
attached wrong file...
Content-Type: text/java;
name="AggregatedUnitItemSemanticEditPolicy.java"
Content-Disposition: inline;
filename="AggregatedUnitItemSemanticEditPolicy.java"
package org.memo.orgml.organisation.diagram.edit.policies;
import java.util.ArrayList;
import java.util.Collection;
import java.util.Collections;
import java.util.Iterator;
import org.eclipse.emf.ecore.EAnnotation;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.gef.EditPart;
import org.eclipse.gef.commands.Command;
import org.eclipse.gef.commands.CompoundCommand;
import org.eclipse.gef.commands.UnexecutableCommand;
import org.eclipse.gmf.runtime.diagram.ui.editparts.IGraphicalEditP art;
import org.eclipse.gmf.runtime.diagram.ui.l10n.DiagramUIMessages;
import org.eclipse.gmf.runtime.diagram.ui.preferences.IPreferenceCo nstants;
import org.eclipse.gmf.runtime.diagram.ui.requests.EditCommandReque stWrapper;
import org.eclipse.gmf.runtime.emf.type.core.commands.DestroyElemen tCommand;
import org.eclipse.gmf.runtime.emf.type.core.requests.CreateRelatio nshipRequest;
import org.eclipse.gmf.runtime.emf.type.core.requests.DestroyElemen tRequest;
import org.eclipse.gmf.runtime.emf.type.core.requests.ReorientRelat ionshipRequest;
import org.eclipse.gmf.runtime.notation.Edge;
import org.eclipse.gmf.runtime.notation.View;
import org.eclipse.jface.dialogs.IDialogConstants;
import org.eclipse.jface.dialogs.MessageDialogWithToggle;
import org.eclipse.jface.preference.IPreferenceStore;
import org.memo.orgml.organisation.AggregatedUnit;
import org.memo.orgml.organisation.ISuperiorLinkSource;
import org.memo.orgml.organisation.OrganisationModel;
import org.memo.orgml.organisation.OrganisationPackage;
import org.memo.orgml.organisation.UnitOfWork;
import org.memo.orgml.organisation.diagram.edit.commands.AggregateU nitLinkReorientCommand;
import org.memo.orgml.organisation.diagram.edit.commands.AggregateU nitLinkTypeLinkCreateCommand;
import org.memo.orgml.organisation.diagram.edit.commands.Interactio nLinkReorientCommand;
import org.memo.orgml.organisation.diagram.edit.commands.Interactio nLinkTypeLinkCreateCommand;
import org.memo.orgml.organisation.diagram.edit.commands.SuperiorLi nkReorientCommand;
import org.memo.orgml.organisation.diagram.edit.commands.SuperiorLi nkTypeLinkCreateCommand;
import org.memo.orgml.organisation.diagram.edit.parts.AggregateUnit LinkEditPart;
import org.memo.orgml.organisation.diagram.edit.parts.AggregatedUni tEditPart;
import org.memo.orgml.organisation.diagram.edit.parts.InteractionLi nkEditPart;
import org.memo.orgml.organisation.diagram.edit.parts.SuperiorLinkE ditPart;
import org.memo.orgml.organisation.diagram.part.OrganisationDiagram EditorPlugin;
import org.memo.orgml.organisation.diagram.providers.OrganisationEl ementTypes;
* @generated
public class AggregatedUnitItemSemanticEditPolicy extends
OrganisationBaseItemSemanticEditPolicy {
* @generated NOT
protected Command getDestroyElementCommand(DestroyElementRequest req) {
IPreferenceStore store = (IPreferenceStore) ((IGraphicalEditPart) getHost())
.getDiagramPreferencesHint().getPreferenceStore();
//check preferences whether to prompt or not
boolean toggle = store.getBoolean(IPreferenceConstants.PREF_PROMPT_ON_DEL_FRO M_MODEL);
if (toggle)
final String DELETE_FROM_MODEL_DLG_TITLE = DiagramUIMessages.PromptingDeleteFromModelAction_DeleteFromM odelDialog_Title;
final String DELETE_FROM_MODEL_DLG_MESSAGE = DiagramUIMessages.PromptingDeleteFromModelAction_DeleteFromM odelDialog_Message;
final String DELETE_FROM_MODEL_DLG_TOGGLE_LABEL = DiagramUIMessages.MessageDialogWithToggle_DoNotPromptAgainTo ggle_label;
MessageDialogWithToggle dialog = MessageDialogWithToggle
.openYesNoQuestion(Display.getCurrent().getActiveShell(),
DELETE_FROM_MODEL_DLG_TITLE , DELETE_FROM_MODEL_DLG_MESSAGE,
DELETE_FROM_MODEL_DLG_TOGGLE_LABEL, false,
store,
IPreferenceConstants.PREF_PROMPT_ON_DEL_FROM_MODEL);
//save user decision for future prompts
store.setValue(IPreferenceConstants.PREF_PROMPT_ON_DEL_FROM_ MODEL, !dialog.getToggleState());
OrganisationDiagramEditorPlugin.getInstance().savePluginPref erences();
if (dialog.getReturnCode() != IDialogConstants.YES_ID)
return UnexecutableCommand.INSTANCE;
CompoundCommand cc = new CompoundCommand();
Collection allEdges = new ArrayList();
View view = (View) getHost().getModel();
allEdges.addAll(view.getSourceEdges());
allEdges.addAll(view.getTargetEdges());
for (Iterator it = allEdges.iterator(); it.hasNext();) {
Edge nextEdge = (Edge) it.next();
EditPart nextEditPart = (EditPart) getHost().getViewer()
.getEditPartRegistry().get(nextEdge);
EditCommandRequestWrapper editCommandRequest = new EditCommandRequestWrapper(
new DestroyElementRequest(
((AggregatedUnitEditPart) getHost())
.getEditingDomain(), req
.isConfirmationRequired()),
Collections.EMPTY_MAP);
cc.add(nextEditPart.getCommand(editCommandRequest));
cc.add(getMSLWrapper(new DestroyElementCommand(req) {
protected EObject getElementToDestroy() {
EAnnotation annotation = view.getEAnnotation("Shortcut"); //$NON-NLS-1$
if (annotation != null) {
return view;
return super.getElementToDestroy();
return cc;
* @generated
protected Command getCreateRelationshipCommand(CreateRelationshipRequest req) {
if (OrganisationElementTypes.InteractionLink_4002 == req
.getElementType()) {
return req.getTarget() == null ? getCreateStartOutgoingInteractionLink_4002Command(req)
: getCreateCompleteIncomingInteractionLink_4002Command(req);
if (OrganisationElementTypes.AggregateUnitLink_4004 == req
return req.getTarget() == null ? getCreateStartOutgoingAggregateUnitLink_4004Command(req)
: getCreateCompleteIncomingAggregateUnitLink_4004Command(req);
if (OrganisationElementTypes.SuperiorLink_4005 == req.getElementType()) {
return req.getTarget() == null ? null
: getCreateCompleteIncomingSuperiorLink_4005Command(req);
return super.getCreateRelationshipCommand(req);
* @generated
protected Command getCreateStartOutgoingInteractionLink_4002Command(
EObject sourceEObject = req.getSource();
if (false == sourceEObject instanceof UnitOfWork) {
UnitOfWork source = (UnitOfWork) sourceEObject;
OrganisationModel container = (OrganisationModel) getRelationshipContainer(
source, OrganisationPackage.eINSTANCE.getOrganisationModel(),
req.getElementType());
if (container == null) {
if (!OrganisationBaseItemSemanticEditPolicy.LinkConstraints
.canCreateInteractionLink_4002(container, source, null)) {
return new Command() {
* @generated
protected Command getCreateCompleteIncomingInteractionLink_4002Command(
EObject targetEObject = req.getTarget();
|| false == targetEObject instanceof UnitOfWork) {
UnitOfWork target = (UnitOfWork) targetEObject;
.canCreateInteractionLink_4002(container, source, target)) {
if (req.getContainmentFeature() == null) {
req.setContainmentFeature(OrganisationPackage.eINSTANCE
.getOrganisationModel_Links());
return getMSLWrapper(new InteractionLinkTypeLinkCreateCommand(req,
container, source, target));
* @generated
protected Command getCreateStartOutgoingAggregateUnitLink_4004Command(
if (false == sourceEObject instanceof AggregatedUnit) {
AggregatedUnit source = (AggregatedUnit) sourceEObject;
.canCreateAggregateUnitLink_4004(container, source, null)) {
* @generated
protected Command getCreateCompleteIncomingAggregateUnitLink_4004Command(
.canCreateAggregateUnitLink_4004(container, source, target)) {
return getMSLWrapper(new AggregateUnitLinkTypeLinkCreateCommand(req,
* @generated
protected Command getCreateCompleteIncomingSuperiorLink_4005Command(
if (false == sourceEObject instanceof ISuperiorLinkSource
ISuperiorLinkSource source = (ISuperiorLinkSource) sourceEObject;
.canCreateSuperiorLink_4005(container, source, target)) {
return getMSLWrapper(new SuperiorLinkTypeLinkCreateCommand(req,
* Returns command to reorient EClass based link. New link target or source
* should be the domain model element associated with this node.
* @generated
protected Command getReorientRelationshipCommand(
ReorientRelationshipRequest req) {
switch (getVisualID(req)) {
case InteractionLinkEditPart.VISUAL_ID:
return getMSLWrapper(new InteractionLinkReorientCommand(req));
case AggregateUnitLinkEditPart.VISUAL_ID:
return getMSLWrapper(new AggregateUnitLinkReorientCommand(req));
case SuperiorLinkEditPart.VISUAL_ID:
return getMSLWrapper(new SuperiorLinkReorientCommand(req));
return super.getReorientRelationshipCommand(req);
--------------010800000008060804030800--
Re: Question (Yes/No) for Delete elements [message #159853 is a reply to message #159418] |
Mon, 12 November 2007 22:43   |
Originally posted by: arvinderbirdi.sbcglobal.net
Somehow this has a nasty side effect for me.
getDestroyElementCommand() is called when I do a simple select and it brings
up the yes/no dialog!
It is not able to delete.
When I do a delete, the dialog shows up and then I'm able to delete.
I am using europa eclipse with java 1.6.0.3. Windows 2003.
"Jan Herriger" <jan.herriger@gmx.de> wrote in message
news:fh4dmn$3hf$1@build.eclipse.org...
> import
> import
> import
> import
> import
> import
> import org.eclipse.swt.widgets.Display;
> import
> import
> import
> import
> import
> import
> import
> import
> import
> import
> import
> import
> * @generated
> * @generated NOT
> getHost())
> boolean toggle =
> if (toggle)
> store,
> return view;
> return cc;
> * @generated
> req) {
> * @generated
> * @generated
> * @generated
> * @generated
> * @generated
> * @generated
Re: Question (Yes/No) for Delete elements [message #160493 is a reply to message #159853] |
Wed, 14 November 2007 23:50   |
I have this problem with a nested node. When it is a top level node, Destroy
element is not called on a selection. GMF 2.0
"arvinder birdi" <arvinderbirdi@sbcglobal.net> wrote in message
news:fhb6gg$shp$1@build.eclipse.org...
> brings up the yes/no dialog!
>> import
>> import
>> import
>> import
>> import
>> import
>> import
>> import
>> import
>> import
>> import
>> import
>> import
>> import
>> import
>> import
>> import
>> import
>> * @generated
>> * @generated NOT
>> getHost())
>> boolean toggle =
>> if (toggle)
>> store,
>> return view;
>> return cc;
>> * @generated
>> req) {
>> * @generated
>> * @generated
>> * @generated
>> * @generated
>> * @generated
>> source
>> * @generated
Re: Question (Yes/No) for Delete elements [message #160895 is a reply to message #160493] |
Fri, 16 November 2007 08:00   |
My fault. Not everything I said is true...
Actually, SemanticEditPolicy *does* show a confirmation dialog when an
element is about to be destroyed.
The dialog doesn't show up after selecting "delete from model" in the
popup menu, because DestroyRequest#isConfirmationRequired is always (?)
set to false. This makes sence, because the user explicitly sais "delete
this element from model" and you don't want to annoy users with
unnecessary dialogs. On the other hand, you might as well take up the
position, that users never really know what they are doing ;-)
As a workaround, I've overridden SemanticEditPolicy#shouldProceed inside
xxxBaseItemSemanticEditPolicy:
protected boolean shouldProceed(DestroyRequest destroyRequest) {
((IGraphicalEditPart)getHost())
((DestroyRequest) destroyRequest).setConfirm(toggle);
return super.shouldProceed(destroyRequest);
One problem remains. If a node has some connections attached, a
confirmation dialog will be opened for every single connection.
Jan
>>> import
>>> import
>>> import
>>> import
>>> import
>>> import
>>> import
>>> import
>>> import
>>> import
>>> import
>>> import
>>> import
>>> import
>>> import
>>> import
>>> import
>>> import
>>> * @generated
>>> * @generated NOT
>>> getHost())
>>> boolean toggle =
>>> if (toggle)
>>> store,
>>> return view;
>>> return cc;
>>> * @generated
>>> req) {
>>> * @generated
>>> * @generated
>>> * @generated
>>> * @generated
>>> * @generated
>>> source
>>> * @generated
Re: Question (Yes/No) for Delete elements [message #161023 is a reply to message #160958] |
Fri, 16 November 2007 17:23  |
Originally posted by: arvinder.birdi.ca.com
I eventually came to the same conclusion.
Only PromptingDeleteAction.createCommand knows about all the selected edit
parts.
In my current implementation a Y/N box is displayed for every selected
EParts. If you select N for any of the EParts the whole group is undone.
You dont have individual Y/N control yet you are asked for every
individual EPart!
-Arvinder
Current Time: Tue Jul 22 15:31:38 EDT 2025
Powered by FUDForum. Page generated in 0.09374 seconds
