Home » Language IDEs » C / C++ IDE (CDT) » problem with CDT 3.0.1 installation with Eclipse 3.1.0 on SUN
problem with CDT 3.0.1 installation with Eclipse 3.1.0 on SUN [message #159217] Mon, 28 November 2005 11:21
Originally posted by: arbi_khelifi.yahoo.fr
I have a blocking problem with the CDT3.0.1 on Eclipse 3.1.0 on SUN/SPARC
workstation.
The installation is well done and when i request to view the installed
plugin the CDT plugin is well installed, however when trying to create a
project there's problem in the "project creation window" when clicking on
the "Next" button, is there others packages that should be installed
before??
here after the Exception:
Unhandled event loop exception
Reason:
org.eclipse.ui.IWorkbench.getHelpSystem()Lorg/eclipse/ui/hel p/IWorkbenchHelpSystem;
java.lang.NoSuchMethodError:
org.eclipse.cdt.make.ui.dialogs.SettingsBlock.createControl( SettingsBlock.java:390)
org.eclipse.cdt.ui.dialogs.TabFolderOptionBlock.addTab(TabFo lderOptionBlock.java:143)
org.eclipse.cdt.make.internal.ui.MakeProjectOptionBlock.addT abs(MakeProjectOptionBlock.java:42)
org.eclipse.cdt.make.ui.wizards.MakeProjectWizardOptionPage$ MakeWizardOptionBlock.addTabs(MakeProjectWizardOptionPage.ja va:58)
org.eclipse.cdt.ui.dialogs.TabFolderOptionBlock.createConten ts(TabFolderOptionBlock.java:98)
org.eclipse.cdt.make.internal.ui.MakeProjectOptionBlock.crea teContents(MakeProjectOptionBlock.java:54)
org.eclipse.cdt.ui.wizards.NewCProjectWizardOptionPage.creat eControl(NewCProjectWizardOptionPage.java:38)
org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.ja va:179)
org.eclipse.cdt.make.ui.wizards.NewMakeProjectWizard.createP ageControls(NewMakeProjectWizard.java:67)
org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:605)
org.eclipse.jface.wizard.WizardDialog.createContents(WizardD ialog.java:496)
at org.eclipse.jface.window.Window.create(Window.java:375)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:983)
org.eclipse.ui.internal.actions.NewWizardShortcutAction.run( NewWizardShortcutAction.java:101)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:989 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:555)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:505)
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:419)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:736)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2948)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2648)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1569)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1540)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:285)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:220)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:710)
at org.eclipse.core.launcher.Main.main(Main.java:694)
Previous Topic:Fixing Indentation
Next Topic:Beta program for Intel® compiler using CDT
Current Time: Sun Aug 31 23:57:12 EDT 2025
Powered by FUDForum. Page generated in 0.03980 seconds
