Home » Language IDEs » C / C++ IDE (CDT) » no binaries and compiler
no binaries and compiler [message #159063] Sat, 26 November 2005 04:51 Go to next message
Originally posted by: max.gabler.gmx.de
hi,
i've got the following problem:
i've installed the c/c++ ide in eclipse and created a new project. but
after finishing creating the project, a warning appeared in the
Problems-window in eclipse. it's the following message:
"Error launching external scanner info generator (gcc -E -P -v -dD C:/
..blabla.. /.metadata/.plugins/org.eclipse.cdt.make.core/specs.c)"
what does it mean and how can i solve this problem?
max gabler
Re: no binaries and compiler [message #159108 is a reply to message #159063] Sun, 27 November 2005 09:47 Go to previous message
Originally posted by: screetch.gmail.com
On Sat, 26 Nov 2005 09:51:47 +0000 (UTC)
max.gabler@gmx.de (max gabler) wrote:
> hi,
> max gabler
looks like gcc is missing. remember that eclipse comes with no C/C++ compiler :) (even the CDT doesn't have one)
if you're using windows :
make sure you have installed MingW correctly (i think it works with cygwin too but i'm not a hundred percent sure) and make sure the PATH variable contains the path to the mingw binary path (c:\mingw\bin for example)
if you're using linux : mke sure the gcc compilation suite is set up correctly
Previous Topic:DOM documentation
Next Topic:Boost.Threads
Current Time: Wed Jul 16 13:07:37 EDT 2025
Powered by FUDForum. Page generated in 0.03655 seconds
