Home » Modeling » GMF (Graphical Modeling Framework) » forbid elements to ( Delete from Model )
forbid elements to ( Delete from Model ) [message #158831] Thu, 08 November 2007 05:58 Go to next message
Originally posted by: juergen.sterr.brainchild.de
we are use GMF to simulate a display from a airplane!
This display shows only text on the screen. The user get textelements via
the palette and somewone represents a static textfield. A static text is
always on a fixed position and a user should not have the possibility to
delete a static textfiel from the model.
How can I forbid the option: ( Delete from Model ) ?
Jürgen
Re: forbid elements to ( Delete from Model ) [message #158839 is a reply to message #158831] Thu, 08 November 2007 06:04 Go to previous message
Originally posted by: trommas.yahoo.com
I think this was discussed earlier here..
check out:
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg08228.html
HTH,
Tomas Zijdemans
Jürgen Sterr wrote:
> via the palette and somewone represents a static textfield. A static
> text is always on a fixed position and a user should not have the
> possibility to delete a static textfiel from the model.
> Thanks
> Jürgen
Previous Topic:Order properties
Next Topic:Problem in creating multiple diagram using same type of model elements
Current Time: Sat Nov 08 20:55:17 EST 2025
Powered by FUDForum. Page generated in 0.02954 seconds
