Home » Language IDEs » ServerTools (WTP) » Elementary problem? - can't publish after moving file?
Elementary problem? - can't publish after moving file? [message #158825] Thu, 02 February 2006 15:55 Go to next message
Originally posted by: eclipse.spfweb.co.uk
Sorry if this sounds like a simple question - but how do I get to re-publish
a dynamic web project after moving a file to a different location under
WebContent - e.g. WebTools/test.html to WebTools/subdir/test.html
The publishing fails with 'Resource /TestWeb/WebContent/test.html does not
exist'
If I copy the file back to where it was, all is well. But then it complains
it can't find test.html in the new directory!!
I'm using WTP 1.0, Eclipse 3.1.2, and I'm publishing to a Tomcat 5.5 server.
(All on Mac OS X 10.4.4)
Thanks for any help.
Steve.
Re: Elementary problem? - can't publish after moving file? [message #158846 is a reply to message #158825] Thu, 02 February 2006 18:27 Go to previous messageGo to next message
> exist'
You might want to try a "Released Maintenance" build. This was
reported as bug 121257, and should already be fixed in the 1.0.1
in-progress builds.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=121257
- Nitin
Re: Elementary problem? - can't publish after moving file? [message #158862 is a reply to message #158846] Thu, 02 February 2006 19:01 Go to previous messageGo to next message
On 2/2/06 23:27, in article dru4gl$onv$1@utils.eclipse.org, "Nitin
> in-progress builds.
Thanks.
Steve.
Re: Elementary problem? - can't publish after moving file? [message #160510 is a reply to message #158862] Mon, 13 February 2006 08:50 Go to previous message
<br><font size=2 face="sans-serif">Until this version will be release you
can just try to &quot;Refresh&quot; your project (with F5) or restart Eclipse
:)</font>
<br><font size=2 face="sans-serif">It &quot;helps&quot; WTP to refresh
project structure and understand that file was moved</font>
<br>
<br><font size=2 face="sans-serif">Hope it will helps.</font>
<br><font size=2 face="sans-serif">Alexey Kakunin</font>
<br><font size=2 face="sans-serif">EmDev Limited</font>
<br><font size=2 face="sans-serif">http://www.emdev.ru</font>
Previous Topic:Newbee: java.lang.NoClassDefFound
Next Topic:publish
Current Time: Tue Jul 22 15:36:52 EDT 2025
Powered by FUDForum. Page generated in 0.03764 seconds
