| newbie launch problem, config question [message #158786] |
Wed, 19 November 2003 05:37  |
Originally posted by: dks.spies.com
I am very new to eclipse... if there is a more appropriate
forum for this question, pls inform me...
I am looking for a clue, such as how to debug this sort of
problem. Any brief pointer would be appreciated...
Upon start up with the following command (on Linux dist RH9):
/opt/eclipse/eclipse \
-data /home/dks/workspace \
-vm /usr/java/j2sdk1.4.2_01/bin/java
I get the following in the log file in .metadata:
!SESSION ------------------------------------------------------------ ----------
!ENTRY org.eclipse.core.launcher 4 0 Nov 19, 2003 02:11:22.621
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.ExceptionInInitializerError
at org.eclipse.core.internal.plugins.RegistryLoader.processMani festFile(RegistryLoader.java:89)
at org.eclipse.core.internal.plugins.RegistryLoader.processPlug inPathFile(RegistryLoader.java:136)
at org.eclipse.core.internal.plugins.RegistryLoader.processPlug inPathEntry(RegistryLoader.java:127)
at org.eclipse.core.internal.plugins.RegistryLoader.processMani festFiles(RegistryLoader.java:104)
at org.eclipse.core.internal.plugins.RegistryLoader.parseRegist ry(RegistryLoader.java:63)
at org.eclipse.core.internal.plugins.RegistryLoader.parseRegist ry(RegistryLoader.java:71)
at org.eclipse.core.internal.runtime.InternalPlatform.parsePlug ins(InternalPlatform.java:890)
at org.eclipse.core.internal.runtime.InternalPlatform.loadRegis try(InternalPlatform.java:834)
at org.eclipse.core.internal.runtime.InternalPlatform.loaderSta rtup(InternalPlatform.java:684)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.core.internal.boot.InternalBootLoader.startup(In ternalBootLoader.java:1040)
at org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:838)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Caused by: java.lang.ClassCastException
at org.apache.xerces.parsers.SAXParser.<init>(SAXParser.java:95)
at org.eclipse.core.internal.plugins.PluginParser.initializePar ser(PluginParser.java:80)
at org.eclipse.core.internal.plugins.PluginParser.<clinit>(PluginParser.java:44)
... 23 more
| Re: newbie launch problem, config question [message #159738 is a reply to message #159728] |
Thu, 20 November 2003 16:35  |
Your problem was including Xerces in the ext directory.
You can see https://bugs.eclipse.org/bugs/show_bug.cgi?id=36643 for more
details
Darins
"DK Smith" <dks@spies.com> wrote in message
news:pan.2003.11.20.21.15.13.276909@spies.com...
> As a follow up to my own post. Maybe it help someone later.
> Also, if anyone with eclipse experience wants to comment on
> "a better way", then I am all ears...
> My error was caused from something I installed after the Sun RPM
> installation was complete. That is, in the directory:
> /usr/java/j2sdk1.4.2_01/jre/lib/ext
> the default installation results in these files (on my system RH9):
> dnsns.jar
> ldapsec.jar
> localedata.jar
> sunjce_provider.jar
> Evidently, I should not install (in this directory) any old library
> obtained from the net. I assume a better way would have been to install
> them in my home directory and use a CLASSPATH variable. The only thing I
> can conclude is that one of these files was the one that disagreed with
> the Eclipse startup process. Did I cause a specific conflict with a
> library that is included as part of the eclipse distribution?
> Here are the files I installed after java was installed:
> avalon-framework-cvs-20020806.jar
> batik.jar
> bsf.jar
> fop.jar
> xalan-2.4.1.jar
> xercesImpl-2.2.1.jar
> xml-apis.jar
> xmlParserAPIs.jar
> Everything is working fine after removing the RPM and installing it again.
> I suppose I could have just deleted the offending files in the ext
> directory, however I wanted to feel that "clean-install feeling". :)
> Cheers
> DK
> (also, if their is a more appropriate newsgroup, pls net me know)
FUDForum. Page generated in 0.03804 seconds
