rotate a text inside a table cell ? [message #158641] |
Fri, 05 May 2006 05:17  |
Hi to all,
I'm using BIRT 2.0.1.
Is there a simple way to rotate the text inside a table cell ?
I know it is possible for a chart axis ... but for table cells ?
Thanks for your help
Dov
Re: rotate a text inside a table cell ? [message #856379 is a reply to message #855460] |
Wed, 25 April 2012 11:59  |
Devin,
Can you try the attached example. I recompiled in 3.7.1, changed the ui
plugin dependencies to optional and exported the jar. The jar and the
project are in the zip.
BTW when I export the jar using the manifest editor, I just copy the
created jar to the web-inf/lib of the 3.7.1 viewer.
Jason
On 4/24/2012 5:05 PM, Devin Wilson wrote:
> Hey I'm really hoping to get some help with this. I went through the 3rd
> Edition 'Integrating and Extending BIRT' instructions for creating a
> rotated text element. However, I'm developing in BIRT 3.7 and after I
> integrate the plugin and run a test report with a single rotated text
> element, I receive this:
> org.eclipse.birt.report.service.api.ReportServiceException: Error
> happened while running the report.
> at
> org.eclipse.birt.report.service.ReportEngineService.throwDummyException(ReportEngineService.java:1107)
> at
> org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:935)
> at
> org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
> at
> org.eclipse.birt.report.service.actionhandler.BirtGetPageAllActionHandler.__execute(BirtGetPageAllActionHandler.java:131)
> at
> org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
> at
> org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPageAll(BirtDocumentProcessor.java:183)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
> at
> org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
> at
> at
> at
> org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
> at
> org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
> at
> org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
> at
> org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
> at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
> at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
> at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
> at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
> at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
> at
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
> at
> org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
> at
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
> at
> org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
> at
> org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
> at
> org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:126)
> at
> org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
> at
> org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:317)
> at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
> at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:390)
> at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
> at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
> at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
> at org.mortbay.jetty.Server.handle(Server.java:322)
> at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
> at
> org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:939)
> at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756)
> at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:218)
> at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
> at
> org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
> at
> org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
> Caused by: org.eclipse.birt.report.engine.api.EngineException: Error
> at
> org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2265)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:190)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
> at
> org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:929)
> ... 49 more
> Caused by: org.eclipse.swt.SWTError: Not implemented [multiple displays]
> at org.eclipse.swt.SWT.error(SWT.java:4308)
> at org.eclipse.swt.widgets.Display.checkDisplay(Display.java:760)
> at org.eclipse.swt.widgets.Display.create(Display.java:896)
> at org.eclipse.swt.graphics.Device.(Device.java:157)
> at org.eclipse.swt.widgets.Display.(Display.java:500)
> at org.eclipse.swt.widgets.Display.(Display.java:491)
> at
> org.eclipse.birt.sample.reportitem.rotatedlabel.util.GraphicsUtil.(GraphicsUtil.java:37)
> at
> org.eclipse.birt.sample.reportitem.rotatedlabel.RotatedLabelPresentationImpl.onRowSets(RotatedLabelPresentationImpl.java:76)
> at
> org.eclipse.birt.report.engine.extension.ReportItemPresentationBase.onRowSets(ReportItemPresentationBase.java:197)
> at
> org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.processExtendedContent(LocalizedContentVisitor.java:1022)
> at
> org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.localizeForeign(LocalizedContentVisitor.java:578)
> Can you point me in the direction of a plugin that will work with BIRT
> and Indigo 3.7? Is rotated text even possible in BIRT 3.7? Anywhere I
> find a plugin or hear something about rotating text it's in reference to
> 2.X versions. If not, do you have any insight into what the issue is
> with my configuration?
FUDForum. Page generated in 0.03192 seconds
