Home » Eclipse Projects » GEF » gef plugin requirements
| gef plugin requirements [message #158635] |
Fri, 19 November 2004 00:26  |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
I am trying to reduce the required plugins for my plugin. I tried to
eliminate
org.eclipse.ui
but the only class that needs it is an Action class which is based on a
class from GEF, SelectionAction. Selection Action is an
org.eclipse.jface.action.Action. And that is in org.eclipse.ui
So does this mean GEF requires org.eclipse.ui. And if it does, why do I
have to include it directly? because I am extending a class that is
based on it? Doesent GEF require draw2d? that is not in the requires
section of my xml file but my plugin still works so far.
What am I missing please!?
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber."
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
| Re: gef plugin requirements [message #158908 is a reply to message #158821] |
Fri, 19 November 2004 21:58   |
I know, but it contains Action. and
org.eclipse.gef.ui.actions.WorkbenchPartAction is based on Action.
So that is why I conclude that GEF requires org.eclipse.ui
correct?
Randy Hudson wrote:
> org.eclipse.ui doesn't contain IAction. It is just a collection of other
> plug-ins and exists for compatibility.
> "CL [dnoyeb] Gilbert" <Lamont_Gilbert@rigidsoftware.com> wrote in message
> news:cnk06v$e7m$2@www.eclipse.org...
>>eliminate
>>org.eclipse.ui
>>Respectfully,
>>CL Gilbert
>>and a robber."
Respectfully,
CL Gilbert
and a robber."
| Re: gef plugin requirements [message #159093 is a reply to message #158908] |
Mon, 22 November 2004 15:18   |
No, it doesn't contain Action either. Action's in the org.eclipse.jface
plug-in.
GEF requires Draw2d and it IS mentioned as a required plug-in in GEF's
plugin.xml. GEF also requires SWT, but doesn't need to include it since it
is already required by Draw2d.
news:cnmbrv$vr0$2@www.eclipse.org...
> correct?
other
message
> >>eliminate
> >>org.eclipse.ui
> >>Respectfully,
> >>CL Gilbert
> >>and a robber."
> Respectfully,
> CL Gilbert
> and a robber."
| Re: gef plugin requirements [message #159162 is a reply to message #159093] |
Mon, 22 November 2004 18:39   |
> plug-in.
Right, so then GEF requires jface.jar?
>>correct?
> other
> message
>>>>eliminate
>>>>org.eclipse.ui
Respectfully,
CL Gilbert
and a robber."
| Re: gef plugin requirements [message #159262 is a reply to message #159198] |
Tue, 23 November 2004 14:08  |
I see ui.jar. What does this have to do with jface.jar?
Randy Hudson wrote:
> Go look inside the org.eclipse.ui folder and tell me which JARs you see.
> news:cnttav$hb7$1@www.eclipse.org...
>>>plug-in.
Respectfully,
CL Gilbert
and a robber."
Current Time: Tue Nov 18 01:53:54 EST 2025
Powered by FUDForum. Page generated in 0.04892 seconds
