Home » Language IDEs » Java Development Tools (JDT) » Configuration problems
Configuration problems [message #158614] Thu, 13 May 2004 12:28
Originally posted by: ltcmelo_java.yahoo.com.br
Hi, please let me know if this is not the correct newsgroup for this kinda
of message, ok?!
I`m writting to this forum, because i`m quite sure i`m having a eclipse
problem.
I recently switched computers and, consequently, needed to reconfigure
stuff.
I'm using eclipse, jboss, xdoclet, easystruts, etc..., what i really think
that doesn't matter to answer my question.
Basically, everything seemed to be ok (as everything worked just fine on
the other computer), but...
If run jboss (with my app deployed) from the command line, everything
works fine (my app, jboss web console, etc...).
When i run jboss from inside eclipse, it starts with no problems, but when
i try to access my jsps, or jboss web-consoler, i get the following
exception.
org.apache.jasper.JasperException: Unable to compile class for JSP
An error occurred at line: -1 in the jsp file: null
Generated servlet error:
[javac] Compiling 1 source file
org.apache.jasper.compiler.DefaultErrorHandler.javacError(De faultErrorHandler.java:130)
org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorD ispatcher.java:293)
at org.apache.jasper.compiler.Compiler.generateClass(Compiler.j ava:353)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:37 0)
org.apache.jasper.JspCompilationContext.compile(JspCompilati onContext.java:473)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:190)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:295)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java :241)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
... continues
I think i might be missing some configuration in eclipse, but i can't
figure it out (i even took some of eclipse folders i have on the other
computer, but didn't work).
Any kind of help will be trylly apreciated.
ltcmelo
Previous Topic:Mouse selection vs. ctrl-arrow
Next Topic:moving packages recursively - is it possible?
Current Time: Tue Jul 15 22:33:50 EDT 2025
Powered by FUDForum. Page generated in 0.05758 seconds
