| CDT 3.0.1 Managed Make and GNU/MinGW Make [message #158579] |
Mon, 21 November 2005 06:06  |
Originally posted by: cgozzini.robur.it
Hi all,
I just upgraded to CDT 3.0.1 from from CDT 2.1.0 on Windows (details of
versions below), building some old Managed Make projects I obtain:
*** multiple target patterns. Stop.
The problem is in this line of the generated makefile:
# Tool invocations
my.exe: $(OBJS) $(USER_OBJS)
If I manually delete the "$(USER_OBJS)", and manually invoke the make, it
all build just fine.
Version 2.1.0 used to generate simply "my.exe: $(OBJS)" and worked just
fine.
Is this expected? Is it now mandatory to use a custom-made makefile instead
of Managed Make to use MinGW's make with CDT? Is there something I'm
missing?
I'm using:
Windows XP
Eclipse 3.1.1
CDT 3.0.1
GNU Make 3.80 (included in both MinGW and Cygwin)
Thank you all,
Cristiano G. Gozzini
| Managed Make and external libraries [was: CDT 3.0.1 Managed Make and GNU/MinGW Make] [message #158848 is a reply to message #158579] |
Wed, 23 November 2005 08:30  |
Hi again,
I've finally resolved.
I try to describe the problem for anyone else that might be in a similar
situation. (Maybe it's an obvious task to most of you, but it proved tricky
for me.)
The point could be re-stated as: what's the proper way to link external
libraries with Managed Make?
The "USER_OBJS" of the previous message were two MS SDK libraries (with .Lib
extensions) which I want to link together with my compiled objects, so I
specified them in the "GCC C++ Linker" -> "Miscellaneous" -> "Other object"
panel (with full path and extension), and with CDT 2.1.0 this just worked.
With CDT 3.0.1 this solution seem to work only at link level (it puts the
libraries simply after the .o in the command line, with no option) but fails
at compile level, since (so it seems) the "Other object" are managed just as
other .o files.
The proper way seems to be:
- add the external libraries names, WITHOUT .Lib EXTENSION and WITHOUT THE
PATH, in the "GCC C++ Linker" -> "Libraries" -> "Libraries" panel
(corresponding to the -l option)
- add the external libraries path in the "GCC C++ Linker" -> "Libraries" ->
"Library search path" (corresponding to the -L option)
- ensure to use g++, and not ld, as link command (which is default, in fact,
but I changed it too during the various attempt)
"Cristiano Gozzini" <cgozzini@robur.it> ha scritto nel messaggio
news:dls9q0$nl0$1@news.eclipse.org...
> Hi all,
> # Tool invocations
> fine.
instead
> missing?
> I'm using:
> Windows XP
> Eclipse 3.1.1
> CDT 3.0.1
> Thank you all,
FUDForum. Page generated in 0.24479 seconds
