how to change linker output name [message #158570] |
Mon, 21 November 2005 05:35 |
Originally posted by: AparnaA.KPITCummins.com
I have integrated a custom toolchain to MBS. I want to give the linkers
output as input to another tool. Also I have multiple .o files as input to
linker. Therefore I have made Linker Inputs multipleOfType attribute as
true.
Now the generated makefile contains the name of my linker output as
default.out. I want to have it same as final build artifact name.
I tried following options but I am not able to do it.
1. I am implementing a nameProvider class with the method-
public IPath[] getOutputNames(ITool tool, IPath[] primaryInputNames) ;
Here I do not understand how to get the name of final build artifact.
I need to get IManagedBuildInfo but I am not getting it.
Is there any way to get it?
2. I also tried with Linker Outputs namePattern as %.out. But makefile
still contains default.out as linker output.
Is there any way to specify name of main input file among multiple
input files?
3. Write own MakefileGenerator.
If the initial two options are not possible then only I am thinking of
modifying MakefileGenerator.
Please help.
Aparna
FUDForum. Page generated in 0.03671 seconds
