Home » Eclipse Projects » GEF » Non-resizable movable nodes
Non-resizable movable nodes [message #158543] Thu, 18 November 2004 15:35 Go to next message
Originally posted by: none.nowhere.com
Anyone know the easiest way to make a node movable but not resizable? Do I
have to implement my own DragTracker to accomplish this?
Peter
Re: Non-resizable movable nodes [message #158557 is a reply to message #158543] Thu, 18 November 2004 15:43 Go to previous messageGo to next message
Use the NonResizableEditPolicy
"Peter Smith" <none@nowhere.com> wrote in message
news:cnj11p$3tp$1@www.eclipse.org...
> Peter
Re: Non-resizable movable nodes [message #158572 is a reply to message #158543] Thu, 18 November 2004 15:43 Go to previous messageGo to next message
I think you would override createChildEditPolicy(EditPart child) in your
XYLayoutEditPolicy, and return a new NonResizableEditPolicy().
- Sean
Peter Smith wrote:
> I have to implement my own DragTracker to accomplish this?
> Peter
Re: Non-resizable movable nodes [message #158588 is a reply to message #158557] Thu, 18 November 2004 15:47 Go to previous messageGo to next message
I presume you mean installing an edit policy in the editpart for the node.
Which role do I install it under?
>> Thanks,
>> Peter
Re: Non-resizable movable nodes [message #158603 is a reply to message #158543] Thu, 18 November 2004 15:50 Go to previous message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
Peter Smith wrote:
> Peter
What I do is alter the editPolicy of the container that will hold it.
Since in the examples, the container is the one responsible for resizing
and moving.
So my container class has an editPolicy ContainerLayoutEditPolicy, and
in the method called createChildEditPolicy, i set the childs edit policy
based on its class type
LineSizeableEditPolicy - I think I created this for feedback purposes or
something.
for those that dont require special handling i call
super.createChildEditPolicy()
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber."
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Previous Topic:GEF examples.text selection
Next Topic:getLocation() of ConnectionAnchor is not called
Current Time: Fri Oct 31 22:55:34 EDT 2025
Powered by FUDForum. Page generated in 0.05233 seconds
