| sporadic indexer behavior [message #158491] |
Fri, 18 November 2005 19:13  |
Originally posted by: brad12s.gmail.com
Hi all - even though there were no posts on my previous question I still
have faith in the CDT community to give me a hand :) - I have been trying
to get the indexing for the CDT working. I have several large projects
and have seen some sporadic behavior. The indexer hasnt been working
since i started using Eclipse and the CDT several months ago. (could be a
user error) Auto complete seems to only show vars from the local scope as
possible completions. Is this a user error, to large of a project or a
feature :)? More importantly, while Last week I was working on my current
project and the index seemed to be working beautifully. I would select an
external object and then hit F3 (Open Declaration/Definition) and it would
perform great by finding the file and open it for viewing. Now this week
there is no joy... I hit F3 or try to do a search and only receive "No
definition/declaration was found" or "0 occurrences". Any help, direction
or work around is greatly appreciated. Thanks - B
| Re: sporadic indexer behavior [message #158510 is a reply to message #158491] |
Fri, 18 November 2005 19:42  |
Originally posted by: m.fortner.sbcglobal.net
I've noticed this as well. It seems to coincide with the outlining
feature sporadic performance. I think it also depends on the indexing.
I've found that when you have several .h or .cpp files open, the icons
on the tabs at the top of the page will change from the normal icons, to
an application icon (as though it can't find the icon resource it
needs). Any file that appears that way can't be outlined. And if you
use the new outline command (Ctrl+O) And the Definition/Declaration
lookups don't work for it either.
Mark
> trying to get the indexing for the CDT working. I have several large
> projects and have seen some sporadic behavior. The indexer hasn�t been
> working since i started using Eclipse and the CDT several months ago.
> (could be a user error) Auto complete seems to only show vars from the
> local scope as possible completions. Is this a user error, to large of a
> project or a feature :)? More importantly, while Last week I was
> working on my current project and the index seemed to be working
> beautifully. I would select an external object and then hit F3 (Open
> Declaration/Definition) and it would perform great by finding the file
> and open it for viewing. Now this week there is no joy... I hit F3 or
> try to do a search and only receive "No definition/declaration was
> found" or "0 occurrences". Any help, direction or work around is
FUDForum. Page generated in 0.02756 seconds
