| GMF2 propsheet [message #158465] |
Tue, 06 November 2007 06:35  |
"Note : If you have no Property Section Container second root, you can now
use our new feature for Adding extension models for gmfgens, available
from the context menu of gmfgen. It should create that second root for
you, when you locate propsheet.ecore and select PropertySectionContainer
to instantiate."
what does it mean? what ecore have I got to set in the popping dialog of
<add extension model>? For sure "propsheet.ecore" is a name of fantasy,
and if I set the name of my only single .ecore I have, it does not like it
and throws errors everywhere.
This since I do not have a "Property section Container" thing.
I'm really freaking out to get just a simple lousy custom tab working!!
p.s. on gmf2
FUDForum. Page generated in 0.02882 seconds
