| Debuggeing remote j9 in eclipse 2.0 fails [message #14846] |
Thu, 01 August 2002 20:17 |
I tried to open a remote debug session with a j9 1.5 (running one
on localhost and once truely remote).
Both times the j9 is waiting for the connect and the connection fails.
Eclipse shows the following error in the log:
!ENTRY org.eclipse.debug.ui 4 120 Aug 02, 2002 01:42:31.907
!MESSAGE Error logged from Debug UI:
!STACK 1
org.eclipse.core.runtime.CoreException[113]: java.io.IOException: EOF
encoutered during handshake
org.eclipse.jdi.internal.connect.SocketTransportImpl.Perform Handshake(SocketTransportImpl.java:138)
org.eclipse.jdi.internal.connect.SocketTransportImpl.attach( SocketTransportImpl.java:42)
org.eclipse.jdi.internal.connect.SocketAttachingConnectorImp l.attach(SocketAttachingConnectorImpl.java:95)
org.eclipse.jdt.internal.launching.SocketAttachConnector.con nect(SocketAttachConnector.java:113)
org.eclipse.jdt.internal.launching.JavaRemoteApplicationLaun chConfigurationDelegate.launch(JavaRemoteApplicationLaunchCo nfigurationDelegate.java:59)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:136)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationDialog$10.run(LaunchConfigurationDialog.java:2299)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:98)
I have tried it with a jdk 1.4 as default jre
and with j9 after installing org.eclipse.jdt.launching.j9_20020625.zip.
It makes no difference
Any ideas what goes wrong ?
Stefan
FUDForum. Page generated in 0.03321 seconds
