Home » Eclipse Projects » GEF » How to get information from user in the getCreateCommand(CreateRequest request)
How to get information from user in the getCreateCommand(CreateRequest request) [message #158387] Wed, 17 November 2004 17:06 Go to next message
Originally posted by: bandrews.nospam_bphnx.com
In my getCreateCommand() method in XYLayoutEditPolicy, I want to get
information from the user, for example the name of the object to create.
I had this working before, by bringing up an InputDialog in my
CreateCommand, but I really wanted to get this information before then
and just pass it to the command. But when I call the InputDialog from
the getCreateCommand(), the dialog just pops up over and over. I realize
it keeps popping up because every time I move the mouse, this method
gets called. My question is what is the best way to get information from
the user before an object is created?
thanks so much!
Barry
Re: How to get information from user in the getCreateCommand(CreateRequest request) [message #158418 is a reply to message #158387] Wed, 17 November 2004 20:15 Go to previous messageGo to next message
Perhaps popping up a dialog when the tool is activated.
"Barry Andrews" <bandrews@nospam_bphnx.com> wrote in message
news:cngi25$84p$1@www.eclipse.org...
> thanks so much!
> Barry
Re: How to get information from user in the getCreateCommand(CreateRequest request) [message #158500 is a reply to message #158418] Thu, 18 November 2004 11:38 Go to previous messageGo to next message
Thanks! I believe this will give me what I want. I do have one problem
that I can't figure out. After I hit OK or Cancel on the InputDialog, I
get a NullPointerException in SelectionEditPartTracker. I can't seem to
track this down as it is happening in another thread. Everything else
works fine.
I can't figure out why the SelectionTool's mouseUp() method gets called
when the mouse up is happening on a button on a dialog.
Is there something else I need to do in my extended CreationTool to keep
from getting this exception?
Here is my code:
public class DECreationTool extends CreationTool
private String objectName;
public DECreationTool()
super();
* @param aFactory
public DECreationTool(CreationFactory aFactory)
super(aFactory);
/* (non-Javadoc)
* @see org.eclipse.gef.Tool#activate()
public void activate()
super.activate();
InputDialog input = new InputDialog(
DrawingEditor.getShell(),
"Name","Name: ","",null);
if(input.open() == InputDialog.CANCEL)
this.objectName = null;
else
this.objectName = input.getValue();
/* (non-Javadoc)
* @see org.eclipse.gef.tools.CreationTool#performCreation(int)
protected void performCreation(int button)
if(this.objectName == null || this.objectName.length() == 0)
deactivate();
return;
CreateCommand command = (CreateCommand)this.getCommand();
command.setName(this.objectName);
this.setCurrentCommand(command);
super.performCreation(button);
Here is the exception:
org.eclipse.gef.tools.SelectEditPartTracker.handleButtonUp(S electEditPartTracker.java:114)
org.eclipse.gef.internal.ui.palette.editparts.ToolEntryEditP art$OtherToggleButtonTracker.handleButtonUp(ToolEntryEditPar t.java:176)
at org.eclipse.gef.tools.AbstractTool.mouseUp(AbstractTool.java :1054)
at org.eclipse.gef.tools.SelectionTool.mouseUp(SelectionTool.ja va:544)
at org.eclipse.gef.EditDomain.mouseUp(EditDomain.java:245)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Released(DomainEventDispatcher.java:359)
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseUp(Li ghtweightSystem.java:528)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:136)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2783)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2442)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1443)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1414)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:271)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
>>thanks so much!
>>Barry
Re: How to get information from user in the getCreateCommand(CreateRequest request) [message #158515 is a reply to message #158500] Thu, 18 November 2004 11:48 Go to previous messageGo to next message
Never mind... I am too quick to post.
If I put the dialog in the performCreation() method instead of
activate(), I do not get this exception. Why, I am still not quite sure.
I will try to figure that out, or if you already know please tell. ;)
This actually works out better, because I would rather the dialog pop up
after the user has selected the location to plop down the object rather
than when the CreationTool is selected.
Thanks for your help!
Barry
> works fine.
> Here is my code:
> super();
> * @param aFactory
> super(aFactory);
> /* (non-Javadoc)
> super.activate();
> else
> /* (non-Javadoc)
> deactivate();
> return;
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>>> thanks so much!
>>> Barry
Re: How to get information from user in the getCreateCommand(CreateRequest request) [message #158580 is a reply to message #158515] Thu, 18 November 2004 15:45 Go to previous message
You should definitely override performCreation, since the ENTER key can also
be used in accessibility mode. The other alternative is to have the
execute() prompt, but I don't think you could handle cancel at that point.
news:cnijq2$96k$1@www.eclipse.org...
> Barry
> > works fine.
> > Here is my code:
> > super();
> > * @param aFactory
> > super(aFactory);
> > /* (non-Javadoc)
> > super.activate();
> > else
> > /* (non-Javadoc)
> > deactivate();
> > return;
> > at
cker.java:114)
> > at
uttonTracker.handleButtonUp(ToolEntryEditPart.java:176)
> > at
> > at
> > at
> > at
java:528)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
java:335)
> > at
> > at
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> > at
..java:25)
create.
realize
from
> >>> thanks so much!
> >>> Barry
Previous Topic:Standalone GEF !!!
Next Topic:GEF examples.text selection
Current Time: Mon Jul 21 21:50:08 EDT 2025
Powered by FUDForum. Page generated in 0.23780 seconds
