How to add WebSphere 5.1 runtime [message #158376] |
Sun, 29 January 2006 23:25 |
I used WTP for some days. It's amazing. For the same project I was
working on, WTP always controlled the memory usage around 150MB. While
for the same project, I used RAD6 which quickly eat up 400MB of memory and
kept growing.
Now the issue is, my target server is WAS 5.1, which cannot be found in
WTP. I don't wanna use WAS 6.0. How I can add WAS5.1 support into WTP?
It seems the only issue for me till now. Since for entity beans, I can
still use xDoclet to manually create, modify bean source file and WTP will
handle the build process.
Any other plug-in, such as JSF, Struts, I don't need them. I prefer to
write in hand.
With XML, Web services, JSP, HTML, Java Script inside, what else you want?
for me, it's enough except for support of WAS 5.1
FUDForum. Page generated in 0.05934 seconds
