Load perspective on startup [message #158348] |
Sun, 25 June 2006 22:53 |
Originally posted by: m040980.yahoo.com.sg
Hi all,
I would like to know is there a way to load another perspective other than
the main one on startup. I'm using RCP.
This means if you do a showPerspectiveBar(true). You will only see the
MAIN perspective in the perspectiove bar. I want to see a MAIN and
SECONDARY shortcut buttons in the perspective bar with the SECONDARY
perspective loaded.
My current problem now is when I do messaging and I receive a message
which causes the second perpsective to show ui changes, it throws an error
because the it is is not loaded yet. I wanna do it programatically and not
manually.
Thanks in advance.
FUDForum. Page generated in 0.09279 seconds
