| eclipse hanging every so often [message #14829] |
Mon, 24 January 2005 13:16  |
Originally posted by: jstansell.fhcp.com
I have a question. I have been using eclipse for about three months now. I
have not installed any plugins at this point. I have seen some behavior
that is a little strange. Seems that about every 10-15 minutes, it hangs
for about 20 seconds doing something then it comes back without any error.
It seems to happen when I have left it for a few minutes, sometimes it does
it, sometimes it does not. It has done it a few times when I was actively
working in it, but not very often. Is there some kind of JVM setting I need
to change? Environment Variable? Other? here is my setup
Windows XP SP2 (firewall turned off)
Eclipse version 3.0.1 Build id 200409161125
Celeron CPU 1.2 Ghz
512 mb of ram
My project is a J2EE utilizing Struts & Hibernate frame works. With no
plugin's added as of yet.
Any suggestions?
| Re: eclipse hanging every so often [message #16011 is a reply to message #14829] |
Tue, 25 January 2005 10:22  |
Originally posted by: Chris_Laffra.ca.ibm.com
This might be the underlying VM doing a global GC?
You may try and give the VM more memory:
http://www.eclipsefaq.org/chris/faq/html/faq26.html
See also the discussion in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=39201
Chris Laffra, http://eclipsefaq.org
"jstanell" <jstansell@fhcp.com> wrote in message
news:ct3dq1$pml$1@www.eclipse.org...
I
does
need
> Celeron CPU 1.2 Ghz
> 512 mb of ram
> Any suggestions?
FUDForum. Page generated in 0.07989 seconds
