Home » Archived » BIRT » Nested Loop in XML DS.
Nested Loop in XML DS. [message #158190] Thu, 04 May 2006 07:48 Go to next message
Originally posted by: kevin.miner.yahoo.com
Is it possible to have nested loop in a table using xml data source?I'm
using BIRT 2.0.1 ver.Is this feature available in this ver?Pl explain.
Thanks in adv
Kevin.
Re: Nested Loop in XML DS. [message #158198 is a reply to message #158190] Thu, 04 May 2006 08:00 Go to previous messageGo to next message
Originally posted by: dsouza.inbox.com
Kevin,
I'm also confronted with the same problem & eagerly waiting for the
solution.
DSouza.
Re: Nested Loop in XML DS. [message #159232 is a reply to message #158190] Tue, 09 May 2006 01:52 Go to previous message
Can you explain what you mean by "nested loop"? An example will help.
thanks,
Gary Xue
Actuate Corporation - Product Development
BIRT Committer
"Kevin " <kevin.miner@yahoo.com> wrote in message
news:f5c80fb029bee150d0dd27c528430822$1@www.eclipse.org...
> Thanks in adv
> Kevin.
Previous Topic:How to specify DB connection details from the code
Next Topic:Problem with XML data source
Current Time: Sat Jul 26 17:52:49 EDT 2025
Powered by FUDForum. Page generated in 0.04718 seconds
