Home » Newcomers » Newcomers » Migrating from JBuilder to Eclipse
Migrating from JBuilder to Eclipse [message #158137] Thu, 22 June 2006 15:07 Go to next message
Originally posted by: pgupta.intercall.com
Is there an easy way or a guide to migrating projects from JBuilder to
Eclipse? Currently i am trying to set up things but still run into some
issues which are taking some time to resolve. If someone has already tried
this, could u let me know the basic steps?
PG
Re: Migrating from JBuilder to Eclipse [message #158153 is a reply to message #158137] Thu, 22 June 2006 15:52 Go to previous messageGo to next message
here is a good documentation about this point:
http://www-128.ibm.com/developerworks/opensource/library/os- ecjbuild/
nicole
PG wrote:
> Hi
> tried this, could u let me know the basic steps?
> Thanks
> PG
Re: Migrating from JBuilder to Eclipse [message #158270 is a reply to message #158137] Fri, 23 June 2006 14:31 Go to previous message
Originally posted by: eclipse4.rizzoweb.com
PG wrote:
> Hi
If you haven't already done so, I strongly suggest reading the "Project
configuration tutorial" that is found under Java Development User Guide.
That should give you all the knowledge you need to set up your
project(s) in Eclipse.
If you still have specific questions, of course posting them here will
usually garner useful specific advice.
Hope this helps,
Eric
Previous Topic:how do I merge changes between to branches in cvs
Next Topic:Can I install swt 3.2 jars only on top of the wtp 1.0.2?
Current Time: Sat Nov 08 15:53:44 EST 2025
Powered by FUDForum. Page generated in 0.08426 seconds
