Home » Eclipse Projects » GEF » Reacting on single-click
Reacting on single-click [message #158121] Tue, 16 November 2004 06:22 Go to next message
Originally posted by: iwan.global.co.za
I have a typical graphical editor and want to open A view (say viewA) when
a user double-clicks on a node (This part solved from the FAQ), and
another view (say viewB) when a user just clicks on a node. (Or
alternatively double-clicks with shift held in).
I like handling opening of the views in EditPart.performRequest(...) as
recommended in the FAQ for double clicks, since it is not a command that
edits the model.
So, the question is - where do I listen for a single click event, or, how
can I check the status of control keys (like shift) at the time of a
double-click from the mouse?
Thank
-i
Re: Reacting on single-click [message #158130 is a reply to message #158121] Tue, 16 November 2004 07:49 Go to previous messageGo to next message
regarding one part of the question below - I found the methods on
SelectionRequest with which you can check keys - is???KeyPressed. But
they always return false (I'm on Eclipse 3.0.0 & gtk).
-i
Iwan Vosloo wrote:
> Hello,
> edits the model.
> Thank
> -i
Re: Reacting on single-click [message #158162 is a reply to message #158121] Tue, 16 November 2004 16:24 Go to previous message
single-click on something which is already selected will send a delayede
DIRECT_EDIT request to the editpart.
Shift+Click is defined as append selection. If you want it to do something
different when the part is already selected, you'll have to extend the
DrgaEditPartsTracker
"Iwan Vosloo" <iwan@global.co.za> wrote in message
news:cncnu4$ior$1@www.eclipse.org...
> Hello,
> edits the model.
> Thank
> -i
Previous Topic:Problems with setting the location/bounds of IFigure
Next Topic:getTargetEditPart method
Current Time: Sun Jul 27 07:21:22 EDT 2025
Powered by FUDForum. Page generated in 0.67583 seconds
