| Reacting on single-click [message #158121] |
Tue, 16 November 2004 06:22  |
Originally posted by: iwan.global.co.za
I have a typical graphical editor and want to open A view (say viewA) when
a user double-clicks on a node (This part solved from the FAQ), and
another view (say viewB) when a user just clicks on a node. (Or
alternatively double-clicks with shift held in).
I like handling opening of the views in EditPart.performRequest(...) as
recommended in the FAQ for double clicks, since it is not a command that
edits the model.
So, the question is - where do I listen for a single click event, or, how
can I check the status of control keys (like shift) at the time of a
double-click from the mouse?
Thank
-i
| Re: Reacting on single-click [message #158162 is a reply to message #158121] |
Tue, 16 November 2004 16:24  |
single-click on something which is already selected will send a delayede
DIRECT_EDIT request to the editpart.
Shift+Click is defined as append selection. If you want it to do something
different when the part is already selected, you'll have to extend the
DrgaEditPartsTracker
"Iwan Vosloo" <iwan@global.co.za> wrote in message
news:cncnu4$ior$1@www.eclipse.org...
> Hello,
> edits the model.
> Thank
> -i
FUDForum. Page generated in 0.03542 seconds
