Home » Eclipse Projects » Eclipse Platform » change text color, icon/label in view
| change text color, icon/label in view [message #158059] |
Mon, 17 November 2003 19:20  |
Originally posted by: jgangemi.yahoo.com
hello -
could anyone point me in the correct direction on how (is this even possible)
i could change the text color in a view? if a project is part of cvs, and the
contents change, i would like to be able to change the color of the file name
to help make it stand out better.
also, when trying to create a GC object w/ a baseImage, such as any label
icon that is associated w/ a java file, xml file, etc i receive an "Invalid
Arugment" exception.
after digging thru the code, it appears that i can only create new GC objects
on bitmaps and not "icons" - why is this so? and what labels an image as an
icon vs a bitmap (i think it has something to do w/ transparency, but not
sure). if i wanted to change the color of one of those labels (say the
"package" label icon that is accociated w/ a java package [it's orange and has
a "plus" sign thru it]) can i build a GC object somehow and manipulate the the
image color that way, or am i going to have to redraw the entire image
"dynamically" (pixel by pixel).
thanks!!!
-jae
| Re: change text color, icon/label in view [message #158770 is a reply to message #158059] |
Wed, 19 November 2003 04:57   |
Originally posted by: daniel.megert.gmx.net
jae wrote:
>hello -
See IColorProvider
Dani
> thanks!!!
>-jae
| Re: change text color, icon/label in view [message #158929 is a reply to message #158770] |
Wed, 19 November 2003 10:04   |
ok - so once i implement that interface, i can control the colors for the
given element, but then how do i "hook up" the implementation so that the view
knows to use it?
thx!
-jae
On Wed, 19 Nov 2003 10:57:14 +0100, Daniel Megert <daniel.megert@gmx.net>
wrote:
>jae wrote:
>>hello -
>See IColorProvider
>Dani
>> thanks!!!
>>-jae
| Re: change text color, icon/label in view [message #159137 is a reply to message #158929] |
Wed, 19 November 2003 19:00   |
>knows to use it?
Set it as your viewer's label provider.
Dani
> thx!
>-jae
>wrote:
>>jae wrote:
>>>hello -
>>See IColorProvider
>>Dani
>>> thanks!!!
>>>-jae
| Re: change text color, icon/label in view [message #159158 is a reply to message #159137] |
Wed, 19 November 2003 21:33   |
ahhh - i see.
but is it possible to override a label provider for an existing view, rather
then having to create a new view?
i could just subclass the label provider and set it w/ that instead, however
i'm not really sure that's the best approach (just b/c if that class ever
changes, my code breaks).
-jae
On Thu, 20 Nov 2003 01:00:38 +0100, Daniel Megert <daniel.megert@gmx.net>
>>knows to use it?
>Dani
>> thx!
>>-jae
>>wrote:
>>>jae wrote:
>>>>hello -
>>>See IColorProvider
>>>Dani
>>>> thanks!!!
>>>>-jae
| Re: change text color, icon/label in view [message #159442 is a reply to message #159158] |
Thu, 20 November 2003 09:44   |
jae wrote:
> ahhh - i see.
No. A viewer has exactly one label provider. You can subclass an
existing label provider and set it to your viewer. Maybe instead of
changing the colour you could use a decorate (see ILabelDecorator).
Dani
>-jae
>>>knows to use it?
>>Dani
>>> thx!
>>>-jae
>>>wrote:
>>>>jae wrote:
>>>>>hello -
>>>>See IColorProvider
>>>>Dani
>>>>>thanks!!!
>>>>>-jae
| Re: change text color, icon/label in view [message #159496 is a reply to message #159442] |
Thu, 20 November 2003 10:57  |
grrr - ok - i had initially explored the use of the label decorator, but ran
into problems trying to change the color of the image decoration b/c i can't
create a GC object against it. (according to the eclipse code, that "icon" is
transparent, and therefore i can't create a new GC object w/ it).
that pretty much left me having to re-draw the image pixel by pixel to get
the effects i want, which i guess is ok, but i haven't quite figured out how to
accomplish that task yet.
is there any way i could manipulate the text color of a label decoration
instead? i'm guessing no since the decorateText method returns a String.
On Thu, 20 Nov 2003 15:44:08 +0100, Daniel Megert <daniel.megert@gmx.net>
wrote:
>jae wrote:
>> ahhh - i see.
>Dani
>>-jae
>>>>knows to use it?
>>>Dani
>>>> thx!
>>>>-jae
>>>>wrote:
>>>>>jae wrote:
>>>>>>hello -
>>>>>See IColorProvider
>>>>>Dani
>>>>>>thanks!!!
>>>>>>-jae
Current Time: Wed Nov 05 02:06:54 EST 2025
Powered by FUDForum. Page generated in 0.03388 seconds
