Home » Language IDEs » C / C++ IDE (CDT) » BUG??: optional parameters in c++ functions call
BUG??: optional parameters in c++ functions call [message #157947] Mon, 14 November 2005 12:59 Go to next message
Originally posted by: fbondioli.autentiweb.com
Hi everybody,
I've a newbie c++ question for you :)
I've a managed make c++ project using eclipse 3.0.1 and the latest
updated CDT plugin
I've a simple c++ function like this one:
std::string trim(std::string& s,const std::string& drop = " ")
std::string r=s.erase(s.find_last_not_of(drop)+1);
return r.erase(0,r.find_first_not_of(drop));
If I call this function this way:
std::string str = " TEST STRING ";
std::string myString = trim(str);
I get the error "too few arguments for function trim"
Isn't this a c++ feature?
The source code get fully compiled but the editors continue showing this
error.
I'm using mingw distribution, not cycgwin. Can this be the cause of the
problem?
Thanks for any hint.
JB
Re: BUG??: optional parameters in c++ functions call [message #158156 is a reply to message #157947] Wed, 16 November 2005 13:42 Go to previous messageGo to next message
Fabio,
just tried it here, works with no problems.
- Does your file have the .cpp extension?
- Which compiler / os are you using?
Max
#include <iostream>
#include <string>
int main()
std::cout << myString << std::endl;
return 0;
Fabio B. wrote:
> Hi everybody,
> updated CDT plugin
> error.
> problem?
> Regards
> JB
Re: BUG??: optional parameters in c++ functions call [message #158264 is a reply to message #158156] Thu, 17 November 2005 12:08 Go to previous message
Max ha scritto:
> Fabio,
> Max
Thanks a lot max for your reply...I've tested your code and it
worked...then I discovered it was my fault since I specified the default
value in the implementation of my function instead of into de declaration.
Sorry but I'm a newbie to c++ (I'm a Java programmer :)))
Fabio
Previous Topic:Standard make: 'Build path' does not work
Next Topic:Cannot set breakpoints
Current Time: Sat Jul 26 17:57:35 EDT 2025
Powered by FUDForum. Page generated in 0.03486 seconds
