Home » Modeling » GMF (Graphical Modeling Framework) » How to control/tweak the distance between a connection and its label?
How to control/tweak the distance between a connection and its label? [message #157886] Wed, 31 October 2007 06:40 Go to next message
When I create connections the attached label is currently always drawn
about 10 mm (~0.4 inches) away from the line.
How can I make this distance shorter? I want these labels to be much
closer to the line they label (say 1-2 mm at most).
Michael
Re: How to control/tweak the distance between a connection and its label? [message #157893 is a reply to message #157886] Wed, 31 October 2007 06:43 Go to previous message
Originally posted by: 5d5.mail.ru
You may add LabelOffsetFacet to the label.
> Michael
Previous Topic:Display connections in outline TreeView
Next Topic:Import from XML errors
Current Time: Sun Aug 31 02:00:54 EDT 2025
Powered by FUDForum. Page generated in 0.03668 seconds
